Aisin Hub Rebuild - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-27-2005, 01:42 PM   #1 (permalink)
Mudlover's Avatar
Aisin Hub Rebuild
I have an '89 4runner that is in need for having the hubs rebuilt. I have found a number of threads on how to rebuild them. But my question is, is there a rebuilt kit I need to buy, or do I just replace the damaged parts? Also, where do I buy these parts? Please do not tell me Toyota.
Thanks for the help.
Mudlover is offline
Old 09-27-2005, 01:46 PM   #2 (permalink)
gthorne's Avatar
What parts are damaged that you are replacing? When I put mine on I just degreased them, put fresh grease on, and put them back together with new gaskets. The gaskets are cheap...I got them from Toyota. If one of your hubs is really damaged you might as well just look for another hub and make it a donor to scavenge parts off of.
__________________
~Garrett
1985 Reg. Cab - Dual cases - Longfields - 33" TSL's
1994 4Runner SR5 - Downey HD Coils - Bilsteins - Yakima Rack.
2003 Tundra - TRD
gthorne is offline
Old 09-27-2005, 01:48 PM   #3 (permalink)
Mudlover's Avatar
I have not started yet. I want to make sure I have everything I need. The only way the lock is with a pair on pliers. They need some help.
Mudlover is offline
Old 09-27-2005, 06:13 PM   #4 (permalink)
Blair's Avatar
Probably some grease. Use a small amount of high quality bearing grease and a large amount of elbow grease. Lube 'em, mount 'em, wheel 'em. And make sure you keep an eye on the little retaining ball mounted on the spring...if you drop it, it's GONE!
If you find broken parts, you can get them from Toyota $$$$. You can build a 'new' hub from their parts counter, but you'd be better off to just get another used one. It will cost less than any part available and you'll have a spare, as mentioned above.
__________________
91 4Runner, 5 spd, with the Mighty 3.0!
0 to 60 in 2.5 liters.
Blair is offline
Tags
4runner, a131, aisin, gasket, gaskets, hub, hubs, kit, lock, manual, parts, rebuild, rebuilding, toyota, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Aisin Hub dino1967 The Classifieds GraveYard 2 11-24-2006 07:05 PM
Aisin Hub rebuild fun ;-) funjumper 86-95 Trucks & 4Runners 7 03-08-2006 11:58 AM
Aisin hub help 87rustbucket General Vehicle Related Topics (Non Year Related) 2 02-08-2006 10:37 AM
Aisin hub question base554 95.5-2004 Tacomas & 96-2002 4Runners 3 06-02-2003 08:36 PM
Aisin Hub Saga donc 95.5-2004 Tacomas & 96-2002 4Runners 2 04-29-2003 01:54 PM
2009 InternetBrands, Inc.
