| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
airbags instead of coils!
__________________
Karl Kraus --Education is a crutch with which the foolish attack the wise to prove that they are not idiots. |
#2 (permalink) |
Airbags are great, unless they leak. Several of us here have airbags inside the coil springs and pump them up for towing. One of mine is now leaking after 3 years.
__________________
03 Dodge Ram 2500 CTD...its amazing Ex: 1999 4Runner JT3HN86R1X0199261...Now somebody elses Karl Malone Toyota 'Certified' POS Legendary Toyota quality is exactly that: A thing of legend. Defective fuel gauge - 'Certified' Defective brake rotors - 'Certified' Defective axle seals - 'Certified' Defective heater diverter - 'Certified' etc. etc. etc. |
#3 (permalink) |
it wount articulate very well and i could see blowing a bag..... inside the coil would be fine though, for occassional heavy laods... however i wouldnt trust a rubber bag to support a vehicle all the time
#4 (permalink) |
Actually they can articulate if cross linked...as far as using them full time. Semi's do...
__________________
'00 SR5, "Highlander" Dual Cases, Aisin Hubs, E-Lock'd, Cryo'd, Chromo'd, ARB'd, 315's, Sonoran Steel Bumper, Lift & UCA's, 4 Crawl 1" BL, Armored...etc. F-Toy #081 in progress Dual Cases, 30 Splines, 5.71's, E-lockers, Hydro-Assist, 37's, DOM Hendrix Chassis, 80Proof, ORS, Sonoran Steel...etc. |
#5 (permalink) |
he isnt talking about air shocks, hes talking about air bags... unless you get the insane huge triple stack ones, there wont be much articulation at all, there jsut isnt enough room to do so... even with crosslinking..... bigrigs dont have much suspesnion travel and they arent meant for offroad... the oens that are setup for offroad, use actual leaf springs packs.....
#6 (permalink) |
I've seen the ones that go inside the springs, but this dude just took two bellow bags, welded a plate on the bottom spring perch, mounted something on the top (sorry I forgot the name, not big in the airbag lingo) and shoved them in, completely eliminating the springs
he had them cross linked, and said the anti-roll bars do a fine job of keeping the car from rolling around too much, however I would be a bit sceptical. another thing he mentioned is that tripple bellow bags have 18 inches off lift crosslink those puppies, and you'd have no problems with articulation! I'm going to stop buy the shop he works at tomorrow, I'll try and grab some pics
__________________
#7 (permalink) |
yeah until you articulate it until the bag blows... then what? you dont have a suspension to support itself.... talk about 3 wheel motin.... except one wheel smashed into the fender
#8 (permalink) | |
Quote:
Here is an example of an install: http://www.fourwheeler.com/howto/80258/ http://www.overlander.com.au/pg/equipment.php?id=29
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#9 (permalink) |
Why don't you get a set of Monroe Max-Air shocks instead that will help you with the sagging rear end and help carry additional loads too. I just bought a set from Advance Auto today, because after moving my gas tank to the rear spare tire location and towing my trailer with my ATVS on it, it's almost to the bumpstops. I'll be installing them today, so we'll see how much they help. I got the MA700's, which are comparable in length to the OME N86 Firms, which is what I have now.
Chris |
#10 (permalink) |
INMO shocks should have nothing to do with supporting the vehicle, they should only be used to dampen.
__________________
#11 (permalink) |
Super Moderator-Sponsoring Member
Staff
Guy at work does all the airbag stuff, he has a dualie w/ them on there to raise/lower the rig, they are the rear suspension and his still rides, tows, does everything...sits at normal level (or wherever) when driving around, but sitting in the parking lot, it is on the ground...
Airbags for just riding around, sure... Airbags for wheeling, no...
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#12 (permalink) |
Don't you guys remember the first rock buggies? The Sniper by avalanche engineerging had air bag suspension front and rear.
Also, about airbags supporting the vehicle all the time...every highway tractor runs solely on airbags...and have for years...I'd say they've proven themselves reliable. |
#13 (permalink) | |
If you're gonna go through all that trouble and still want to go offroading, why not just go for some type of hydraulic unit? I know that some company just recently tested some sort of hydraulic suspension setup on jeeps, I think I read it somewhere in 4wheel and offroad a few months back.
__________________
1998 4Runner SR5, Surco Safari rack, diff breather mod, Cobra WXST II CB radio, 31" Winston ATs, clear corner/bumper lens, hitch mount backup lamps, PCV catch can. Quote:
#14 (permalink) |
The only thing that would concern me would be a severly misplaced stick or something that gets hung around the tire and punctures the airbag while on the trail. Very unlikely, but it could happen.
#15 (permalink) | |
Quote:
Chris |
#16 (permalink) | |
Quote:
And besides...I'm sure most of you actual wheelers have seen many leaf springs break over the years. That's never convenient. An extra airbag would be small to carry, light, and easy to chage. I hope I'm not pissing anyone off here, but I just like to see new ideas in action. I realize that newer doesn't mean better, and that for every 10 ideas 1 might be useful, but if someone wants to try it, lets wait and see their results, and offer as much help as we can along the way. Last edited by grandmasterE; 05-30-2005 at 03:08 PM. |
#17 (permalink) |
I know a guy who had a bagged Jeep Rubicon on 36's I think. They were designed for offroad. He could lower it down for the street and jack that thing WAY up for offroad. It was like a monster truck. Not only did he not have problems he faired better then people with lifts on 35+ tires.
Only problem with them is that its just something else to break and alot of components.
__________________
06 Subaru WRX |
#18 (permalink) |
It will never work!! (Ohh and BTW the sky is falling)
\/ \/ \/ \/ (not mine) \/ \/ \/ \/ ![]() ![]() Ohh did I mention those are 37's
__________________
1990 Xcab beast of burden 3.0 Rebuild/Precision balanced w/OS valves Custom ported/welded Intake manifolds Downey headers, Jacobs Ign 4" Trail Gear SAS + rear Kit R151 + Dual cases (2.28+4.7) 5.29's,Tru Trac/Lockright on 35 BFG's 140A GM CS144 alt/Hyd assist steering DOA Racing = $1200 lesson in who NOT to deal with Last edited by Ganoid; 05-30-2005 at 07:19 PM. |
#19 (permalink) | |
I think I remember seeing that truck before. I'm quite impressed by the flex.
__________________
#20 (permalink) |
be neat being able to lean the truck....could take on some interesting terrain at interesting angles if you could lean the weight
__________________
06 Subaru WRX |
#21 (permalink) |
Its a local shop that built it. All the bags are capable of independant control. Its still a work in progress currently running a TPI 350 connected to a TH350. He was still working on brakes and drive lines for those full width chevy axles that he welded on both ends. I think he said the bags are 15" travel but all of the pics I have are at full lift. When he deflates it down to minimum it looks just like any other truck running a 4" lift with 35's only they are 37's
__________________
1990 Xcab beast of burden 3.0 Rebuild/Precision balanced w/OS valves Custom ported/welded Intake manifolds Downey headers, Jacobs Ign 4" Trail Gear SAS + rear Kit R151 + Dual cases (2.28+4.7) 5.29's,Tru Trac/Lockright on 35 BFG's 140A GM CS144 alt/Hyd assist steering DOA Racing = $1200 lesson in who NOT to deal with |
#22 (permalink) |
Hey guys, I just started a post about my experience with my new Monroe MA700 air shocks here: http://www.yotatech.com/showthread.php?t=60181 if anyone's interested! It's a quick and easy way to eliminate the sagging rear end.
Chris |
#23 (permalink) |
I think that is a bit extreme!
I'm thinking of this as a solution to having the truck look like it has a 4 inch lift in the front and stock ride height in the rear. I'm going to the shop that the dude works at tomorrow to talk to him more about it.... My digi cam was sent out for warranty otheriwse I'd snap some pics for you.
__________________
#24 (permalink) | ||
Quote:
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| OME Coils 880 Front coils and 99 Coils | aviator31 | The Classifieds GraveYard | 15 | 08-24-2007 06:42 AM |
| Airbags (SRS) and wheeling? | SuaveGato | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 05-25-2006 05:37 PM |
| TRD airbags | Ishinc | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 07-22-2004 09:27 AM |
| Airbags? | 4runner4lyfe | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 05-09-2003 08:57 PM |
| Airbags... | rpeAMP | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 12-13-2002 08:14 PM |
