Airbag Light
Old 09-01-2004, 03:11 PM
mrmojorisinphan's Avatar
Airbag Light
Does anyone know how to turn the airbag light off, the bags have not deployed but the light turned on...I'm hoping there's an easy way to reset it...
any help is appreciated
trevor
99 4runner
Old 09-01-2004, 03:54 PM
Jonathan's Avatar
trevor
99 4runner
Actually when you least expect it they're gonna fly out and knock your front teeth out. JK i don't have an answer, but here's abump for you.
Old 09-01-2004, 03:58 PM
Tacoma Dude's Avatar
Did you pull the fuse? My Camry alarm used to be wired into the airbag fuse and everytime we pulled it the light would come on.
Try pulling the negative terminal off your battery for a couple minutes. See if that reset will help your situation.
Old 09-01-2004, 04:40 PM
nunsa's Avatar
trevor
99 4runner
You have to go to the dealer for this one, they have a SST(special service tool) to reset that light. The'll sock it to you, probably $50+!
You could try to disconnect the battery, but It probably won't work!
Good Luck!
Old 09-01-2004, 06:57 PM
User 051420's Avatar
Good Luck!
I second this idea. The airbig system is pretty freakin important to mess around with..
Old 09-01-2004, 07:43 PM
It cost me $100+ to take in the Camry and do this stuff...
I know this isn't what a lot of people would do but if I knew it was because I pulled the fuse, I would really just unplug the battery and reset the stupid thing. If the idiot light came back then yeah, I'd definitely take it into the dealer.
Old 09-02-2004, 08:07 AM
Thanks for the reply's.... i'll try to reset it myself, hopefully I wont have to take it to the stealer
Old 07-12-2008, 11:09 AM
homerut's Avatar
airbag light on
My 04 4 runners airbag light just came on and stays on. They charged me $98 to diagnose it and want $1000 to fix it. I only have 46,000 miles on it. It looks like it would be covered under the warranty. I can't afford this now. Any suggestions? The codes were B1100 and C1336.
Old 07-13-2008, 07:35 AM
DailyDrive's Avatar
Flip flip flip. Aha B1100 is "Airbag sensor assembly malfunction". Flip flip flip, new airbag sensor harness $500. That will be $1000 sir!
Take it to some place that fixes cars, not replaces parts.
Old 07-13-2008, 01:52 PM
homerut's Avatar
What does the code C1335 mean?
Old 07-13-2008, 01:53 PM
homerut's Avatar
I mean C1336
Old 07-13-2008, 03:35 PM
DailyDrive's Avatar
I mean C1336
Looks like you (or someone with a very similar truck and code) already got an answer here: http://toyota.justanswer.com/questio...4-toy-4-runner.
Old 07-13-2008, 10:24 PM
98runner210's Avatar
why the hell would u wire anything into the airbag circuitry?! all it takes is 12 volts to fire...
ashersullivan88yota
01-18-2022 05:37 PM
4.34runner88
08-11-2018 10:44 AM
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
Quick Reply: Airbag Light
