Airbag Light On
Old 10-14-2014, 08:29 AM
Newby's Avatar
Airbag Light On
Hello guys,
I found a 99 Toyota Tacoma SR5 V6 4x4 5 Speeds and I'm interested for it a lot but the Airbag Light is On now. Do you know what's wrong with it? Is there an easy to fix? I need to know the problem before I buy it, that's why I bring this up for you to help me.
I need your subjection please
Old 10-16-2014, 04:37 PM
Junkyard Dog's Avatar
See if the current owner will take the truck by a parts store such as Advance or Autozone and let the folks there read the airbag codes thru the OBDII.
Depending on what the code is should help you decide...
Bad front sensor, not too bad $$ wise, but if one of the airbags or the DERM is faulty that could be a big expense. Gives you more wiggle room to negotiate the price though, if you really want the truck.
Old 10-16-2014, 08:56 PM
TheDurk's Avatar
You can't read airbag codes with a standard OBDII scanner. Needs Toyota Techstream. I don't think those parts stores have anything that can do that.
Old 10-17-2014, 05:27 AM
My bad. Thought Generic OBDII could do SRS/ABS as well.
No way to retrieve airbag codes other than at the dealer then?
Old 10-17-2014, 10:36 AM
Newby's Avatar
According to the owner told me, he never took it to the dealer or any auto part to scan to see what's wrong with it.
The truck has 6 problems as the following:
1. The Paint is bad
2. The Airbag Light is On
3. The A/C is not cold
4. The Real Bumper is bent
5. The Clutch is not working
6. The left Front Bumper Filler is rusty
The major problems to me are the Airbag Light On, Paint, Clutch, and Real Bumper.
The Paint itself runs me about $800 for the basic paint only at Maaco, but I don't know how much do they charge for the other things. Usually how much do you pay for the repair on those problems?
Old 10-18-2014, 07:27 AM
TheDurk's Avatar
For like $25, I bought a compatible cable on e-Bay and downloaded Techstream, so I can read them on an old XP laptop. (works best on XP). Here is the thread I used:
http://www.tundratalk.net/forums/3662490-post975.html
Old 10-18-2014, 06:03 PM
KZN185W's Avatar
Bumper is damaged? maybe the airbag deployed in a collision and there's no airbag in the replacement
Old 10-22-2014, 07:11 AM
Newby's Avatar
Thanks for the link.
Old 10-22-2014, 07:12 AM
Newby's Avatar
I'm not so sure, but thanks for your subjection. The owner claims that the truck is a clean title and it never had any accident before. The real bumper was hit a tree at his backyard when he backed up, but it could be as you said.
ashersullivan88yota
01-18-2022 05:37 PM
4.34runner88
08-11-2018 10:44 AM
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
Quick Reply: Airbag Light On
