air question
Old 01-14-2004, 01:22 PM
Question air question
Hey,
I have 91 4Runner, 3. slow 2WD.
Do you know what regulates the amount of incoming air when the engine is warm?
The problem is that when I drive it for a while, then let it stand for 10-20 minutes and start it back up, the engine is idling rough and on very low rpms. Every once in while the engine even dies because of it. So, my mechanic told me that there is the problem with regulating incoming air when the rig is hot.
Thanx for your responces
Old 01-14-2004, 06:57 PM
...and, oh yeah, my mechanic told me that it's not MAF sensor.
Thanks
Old 01-14-2004, 08:00 PM
Firefyter-Emt's Avatar
TPS ???
Old 01-14-2004, 08:23 PM
The TPS has been changed 5K miles ago, although it's adjusted ALMOST perfectly, but the problem still exists.
Old 01-15-2004, 02:14 AM
toy283's Avatar
The only things that regulate the airflow in the engine (any engine) are the throttle butterflies and thus the throttle peddle. MAF, TPS, O², etc. all regulate fuel flow in accordance for proper burning efficiency.
Old 01-15-2004, 07:04 AM
Unhappy99's Avatar
I would be of the opinion you are experiencing a fuel problem, not an air problem. How many miles on your vehicle? When was the fuel filter replaced? When were the injectors cleaned? How often do you put injector cleaner in the fuel tank?
Old 01-15-2004, 08:11 AM
rimpainter.com's Avatar
You have a VFM not a MAF anyway.
Old 01-15-2004, 10:01 AM
My truck has 99K miles on it. The last time I've put any injector cleaners in the fuel was 6 month ago. And the fuel filter was changed a year ago (12000 miles).
Old 01-15-2004, 10:05 AM
If you give it gas during this condition, does it sputter and idle up?
In other words, does it get smooth as you put your foot in it?
Do you have an Auto or 5spd.?
Old 01-15-2004, 10:32 AM
cubuff4runner's Avatar
I don't know to much about this but do you possibly have a gas line which got pushed near part of the engine block or other hot spot so it is kinda vapor-locking? It may only get hot enough when it is stopped for a period of time.
Old 01-15-2004, 12:27 PM
Yea, when I push the gas pedal just a bit, engine runs smooth. And I have a automatic 4x2
Old 01-15-2004, 01:51 PM
MTL_4runner's Avatar
Have you cleaned the throttle body?
That will certainly make it idle rough.
Old 01-15-2004, 10:56 PM
As far as I understood, T body, if it was the problem, would make the idle to be rough all the time and not just when it's hot and been standing for a while. Am I wrong?
Old 01-16-2004, 02:23 AM
Guest
foxtrapper's Avatar
There are three seperate air passages controlling idle on your engine. One is the butterfly or "throttle" in the throttle body. The second is the idle speed circuit which is a controlled bypass around the throttle. The third is the cold start circuit which is another larger bypass, but this one is controlled by a thermostat. There's a few others, like the a/c circuit that also partially control idle, but we'll leave those alone for now.
When warmed up, the idle air goes through the throttle a little, and through the idle speed circuit. Dirt on the throttle wreaks havoc on the idle speed, particularly when warm, and creates roughness, low idle speed, and stalling. Warm idle speed adjustment is a simple matter of opening up the adjusting screw on the idle bypass. Something your mechanic should have attended to. There is also the distinct possibility that he's screwed around with the main throttle butterfly, which has a very precise setting for idle. If that one is screwed up, you must correct it first.
So, clean your throttle body, check the throttle plate position when closed, and adjust the idle speed correctly on the idle speed circuit. At which point you will probably be fine.
Old 01-16-2004, 06:16 PM
Do you guys know how to clean the T. body? I've done a search but came up with nothing.
Thanks
Old 01-20-2004, 02:21 AM
Guest
foxtrapper's Avatar
Carburetor cleaner and a tooth brush. I've a very simple job.
Thanks
the1998sr5
15
07-14-2020 08:35 PM
RatOmeter
10-22-2015 03:17 PM
tj884Rdlx
08-28-2015 12:04 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: air question
