Air/Fuel sensor
Old 01-07-2009, 09:37 PM
campintruck's Avatar
Air/Fuel sensor
My check engine light came on Monday after a camp out this past weekend. I took it to Autozone after work and the scanner read P1135. I couldn't believe what I was hearing, but the guy told me that I need to change my oil! I know this means that my Air/Fuel sensor needs to be replaced after searching this forum. My question is: Can I wait til Monday to replace the part and will my catalytic converter get clogged up? I really can't order the part til Friday from Toyotapartsexpress. Thanks for the info!
Old 01-08-2009, 05:45 AM
97ltd4x4's Avatar
I doubt driving the vehical for a few days will hurt the cat...Don't worry about it,just get the sensor in the vehical as soon as you can.
Old 01-08-2009, 08:15 AM
BigBallsMcFalls's Avatar
you will have 1000 miles of crappy gas mileage before problems will start to add up
go ahead and replace o2 sensor too, if u haz money....it will fail soon enough
Old 01-09-2009, 10:12 AM
Thanks for the advice. I want be able to do the o2 sensor yet, thanks to my boses for not paying me for my days off during christmas break. Ill be lucky if I can buy my a/f sensor next week.
Old 01-09-2009, 10:51 AM
97ltd4x4's Avatar
Don't worry about the sub2(it only works hard once the cat works hard/dosen't work)...just get the sub1 in there(A/f)...All will be fine.
Old 01-09-2009, 12:21 PM
well, when the a/f isn't working the crap can build up on the o2 and (yes crap goes through the cat, doesn't get burned) shortens the life...that's alll I meant
plus the denso quality control is pretty good. when the element on the a/f goes (from old age, molecular loss) the o2 is also about ready to die. just sayin...if you can afford the pair may as well do them
but yes, rear may last another 40,000 miles who knows ? usually they go about 2 months between 1st death and 2nd death
Old 01-09-2009, 10:08 PM
TheDurk's Avatar
I'm cheap and sensors aren't. New A/F sensor cured the P1135 I got at 70k and I stopped there. I figured the O2 lives in a lower temp post-cat environment and might have a few more miles in it. I'm at 110k now 3 years later and I'm not going to change it until it throws a code at me; it has no effect on how the truck runs. What's your sample size on that two months?
Old 01-12-2009, 07:06 PM
marktwo's Avatar
Bad effects? Crappy gas mileage.
Be careful pulling that sensor out ... I've priced many a manifold/exhaust pipe for impatient technicians who've ripped the threads out. PB Blaster the hell out of it a few times the day before you go to replace it, or a "hot wrench" can work wonders.
Old 01-13-2009, 05:51 AM
I had to chisel and peel the nuts off. them things just melt over 10 years and turn into rounded nuts 2 sizes too small...
moparbay
03-10-2023 03:50 PM
jb451
7
10-07-2022 06:58 AM
Kreedy1
09-08-2015 06:33 PM
zz_denis
09-06-2015 03:43 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: Air/Fuel sensor
