Aftermarket tachometer
Old 08-10-2011, 12:16 AM
Johnboy21's Avatar
Does anyone know where to hook up the reader wire or wire that hooks up to your coil on a 3rz tacoma motor? I've searched high and low and looked over the wiring diagrams in my fsm and i cant find a decent wire to hook this up too. The coil's internal on this distributor and i think if I was to hook it up i would have to splice into the wiring harness coming off the distributor and I'm trying to avoid doing this. My truck came without a tachometer from the factory. My truck is a lifted 96 tacoma with a 2.7 4banger. Any advice is appreciated.
Old 08-10-2011, 08:18 PM
Kerby J's Avatar
at the igniter located on the left side of the engine compartment and it is the black wire
Old 08-11-2011, 08:09 PM
Johnboy21's Avatar
thanks man just now found it so i just splice my tach wire into that or what?
Old 08-14-2011, 12:31 PM
Kerby J's Avatar
yea just solder it on there and you will b good to go
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
justdifferentials
14
06-11-2017 08:36 PM
SpookyMulder
11-04-2015 11:56 AM
Tcsdef
09-07-2015 11:17 PM
Quick Reply: Aftermarket tachometer
