Aftermarket Reversal Light Mounting Location (idea for mount, with pic)
I picked up a couple tractor lights from Napa today, and was thinking highly of mounting them here:
They could flip up out of view when not needed, wouldn't have to worry about damage, easy to route wire. Any cons?
You know, I started thinking about the same thing after seeing robinhood's pictures in this thread
https://www.yotatech.com/forums/f2/4runner-lodging-not-dial-up-friendly-28390/
but after looking at his again i think they are more for interior light. I say go for it, they would throw a ton of light when you need it, and like you said be out of the way when you don't.
Originally Posted by turboale
The window will have to be down otherwise you'll be shiningthem at yourself...
Other than that... no
Originally Posted by jimabena74
haha, you edited out your license plate # in the thread pic, but its in your avatar... doh!
If my plate in my avatar looks funny, it's because it's photoshopped!
Sucker!
No, I don't recommend mounting them inside. Even with the window down there is way too much glare from the sides of the lights illuminating the inside.
I don't recommend anywhere near the hitch either, I know if I had done that they'd get smashed the first time out on the trail. I ended up mounting mine on the rear of the roof rack, but mine are small.
They will only be used when the window is down, I'm not wiring them to come on when I shift into reverse.
I mounted them up last night at 11 in the dark (couldn't sleep). Looks pretty good, I think it will work well.
Location: Bend, Oregon. 4mer Teufelhund, now a DoD Contractor
I'm just curious but if you have to flip them down to use them,and you don't wire them up to the reverse lights ....when will you use them?
They are installed and working great.
I don't flip them down to use them, I flip the up when they are in the way (sleeping in the back, lots of cargo, etc).
I intend on using them when reversing at night on trails, and while unloading a campsite at night. When I flip them up, they light up my cargo area amazingly well which will come in handy for when I'm unloading in the dark.
Plain and simple, I got tired of using a maglite. These work perfectly for what I wanted.
I finally managed to stay up long enough to see darkness.
Here are some photos of the finished product at night:
Here is pointing down inside of the cargo bay. (The color wasn't edited in photoshop either)
Here is pointing out behind me, with the spare tire blocking a bit of light.
It's been awhile since I took night photos of anything, I think these turned out rather well.
If anyone else does this in the future, you can't use your rearview to reverse, you'll have to use the side mirrors to see anything. Alot of the light does get reflected back into the cab.
Still alot better then having them outside though.
Good mod - I had 4 of those on my old rig. Only like 9 or 14 buck each. I had 2 on the frame facing the side for alley lights and 2 on my topper facing back. Bolted them t the side and bent them down - they did not hang bleow the frame.
With my new 4runner I have just a single on the drivers side frame facing back. The bolt that come with the light fit a hole with threads that came on the truck. I did have to move the stock wireing set up to towing - I just took off the barcket and moved it to the top of the frame out of the way. Made the back a bit cleaner. I still want to add some side facing lights. If I found some cheep oval shaped lights I would mount them to the side frame and notch the running boards for the lights to face out.
Originally Posted by tulsa_97SR5
Kudos on trying something different, even if most said not to. Was the light that was reflected back in mostly due to the spare (which most of us don't have there)?. Would extending the housing around the lights to make them more spot light than flood help?
You can see in that photo that the light hits the inside pillar and window, which lights up the interior and causes the glare. I was thinking of making a housing for them, but it doesn't bother me enough.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
