Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Advice for a smoother ride
Hello all!
I live in a rural area with roads that are bumpy, rutted, and generally in poor condition even though they are paved. When I installed the Revtek lift I noticed that the coil spring is compressed even more than stock. I suspect this contributes to a poor ride. Whatever the case, I am sick of being tossed around on my way to work and would like any advice you've got. Would coilovers solve my poor ride quality? OME? Thanks!
__________________
2004 Tacoma Double Cab, TRD Off-Road, PIAA fogs, ARE Shell, Yakima, etc. 4RunnerFever _______ GBNF: 1998-3rd Gen-4Runner, SR5, 4WD, TRD Supercharger, TRD Cat-Back, 3-inch Revtek Suspension Lift, 285/75-16 Revos, 4Crawler Offroad 1" body lift, Sonoran Trac Bar, Hayden Cooler, Hood Scoop, 'Outback' Mod, Optima 34R, Amsoil, Yakima, PIAA, etc. Sold to Mastacox. |
| Sponsored Links |
#2 (permalink) |
:chicken:
__________________
#3 (permalink) |
I was anti any device on my 3rd gen that preloaded the spring to get the lift...it just had to be worse riding. The revtec kit gets lift from preloading the spring and lengthening the strut.
I had the same issues. I went to Tundra valved Sway-a-ways on the front which were night and day for me. They rode as smooth as stock at moderate lifts with far improved control. I was running about 2" in front to clear my 32s as I still had ADD hubs so did not want to tweak the CV joints too bad... I had Downey Coils in back which were a little firmer than I would like but the handling was much tighter and sharper. David
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow 93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ... 03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-( 99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten 96 SR5 Dune... 1.5kw stereo |
#4 (permalink) |
If you are running the Revtek lift with the stock shocks then I would probably try a different set of shocks first if I were you.
__________________
2006 Subaru Outback, miss my 4Runner! Look at my previous truck(s) in the Yotatech gallery: http://yotatech.com/showthread.php?t=42494 |
#5 (permalink) |
Thanks for the suggestions. Would you recommend OME shocks or Bilsteins? I was also looking at the performance products sway-a-way coilover kit. Keep the suggestions coming!! I gotta do something.
http://www.performanceproducts4truck...r+Kits&type=20
__________________
#6 (permalink) | |
Quote:
If money is not an issue, the coilover setup has got to be one of the better alternatives. If it is an issue, how about the Tundra setup with OMEs in the rear and Bilsteins all around or just upgrade the shocks and see how this works? |
#7 (permalink) | |
Quote:
__________________
#8 (permalink) | |
Quote:
Now, go to Revtek ($300) plus Bilsteins ($300) and you're at $600 plus install. I never got price info on the Tundra stuff but I'm assuming you'd be in the same price range. Since you have the Revtek, why not just try the Bilsteins first? I don't pay for labor so I'd do this. If the ride sucks, then upgrade springs. If you pay for labor, you should consider the full swap and selling the Revtek kit to compensate for the switch. Just a thought... |
#9 (permalink) |
I can only offer advice from what I have used.
Front: Stock: Everyone knows the feel. Tundra Valved SAW's: Like said before a night and day feeling from a shot stock setup, but it does not last all that long, around 30k they really need rebuilding and that can also include the heim? joint (the bottom joint that seems to end up on everyone's SAW's that sqeak horribly). So every 30k they need some if not a lot of maintenace. Up here in the salt belt the spring did not end up looking great the powdercoating came off and the spring is rusting. I took mine off, and will not point anyone in their direction. They are not built for longevity. TRD: (Tundra springs, OME shocks, top spacer) So far for me the best setup. I like the ride a lot better than the SAW's. On the highway at speed they behave nicer than the saws do. Only small problem is the spring rubbing where it does. Rear: Bilstein/Downey: Love it. Yet I honest have not ridden in back to know the feeling of the ride, but it holds weight nicely. I carry 500lbs of DJ gear twice a week in mine and it does not feel like any weight at all is back there.
__________________
-Pete RIP *97' 4Runner SR5* New baby: 07' Sport v6 Shadow Mica Last edited by li_runner : 10-05-2005 at 11:39 AM. |
#10 (permalink) |
Try some OME shocks for starters.
I think that will help a lot. |
#11 (permalink) | |
read my sig. That is the best set up period. Not that expensive and the ride is supurb on and off road.
Come to Richmond adn I will help install it. I have a wall mount spring compressor, air tools, garage....I have done three of these already
__________________
Eric 88 4runner Quote:
#12 (permalink) | ||
Quote:
__________________
#13 (permalink) | |
Quote:
I might actually take you up on that offer maybe over the xmas season.What do you all think of just OME in the front?? Worth a try, or go Bilstein because they are cheaper.
__________________
#14 (permalink) | ||
Quote:
Call up Sonoran Steel and get a pnahard bar or bracket and e-brake extension and new bumpstops. I love my suspension. The only change I will make is the addition of anothe top out spacer (heavy ARB bumper and I am getting a winch) My wife has the PP 1" springs with HD billies. It is a nice ride, but you can definately tell the difference between the Billies and OME---two different shocks.
__________________
#15 (permalink) |
I have the Revtek 3" kit up front, combined with OME firm shocks. I've been really happy with this setup, and in my opinion using OME shocks with the spacers up front provides a really comfortable ride.
__________________
2000 4runner Limited 4wd, TJM-15 w/Hella 500s and Warn m8000, Stubbs Sliders, Surco safari rack, 3" Revtek in the front, 890s in the rear, OME firm shocks, 2" RB body lift, Custom Hitch, 285/75 MT/Rs, K&N FIPK, Dual Exhaust, remote start, Pioneer 8600, 2 JL Audio 12s |
#16 (permalink) | |
Quote:
Seems like new shocks up front is the way to go.
__________________
#17 (permalink) |
Come on - take the cool route for a smooth ride - get heavy duty coils and shocks and add very heavy bumpers, a winch, and big tires.
Nice and smoooooth......
__________________
1996 4Runner & 1971 FJ40 |
#18 (permalink) | |
Quote:
__________________
