Advantages of Larger Wheels?
Old 11-30-2014, 09:52 AM
forsyth793's Avatar
96 4Runner with stock 6 Lug 16" Aluminum Wheels....
Is there any advantage in later 17" or 18" Wheels???
Old 11-30-2014, 11:21 AM
JasonYota's Avatar
Looks, clearing larger brake calipers. More expensive tires
Old 12-01-2014, 02:45 AM
Texas_Ace's Avatar
Larger wheels are only better under 2 basic situations.
A: To clear larger brakes as said above, in our case this is not a problem.
B: If you plan on tracking the car on a course around corners and the tire size you want to run needs a larger wheel. Also not an issue with our trucks.
Otherwise a smaller wheel will generally be best. Better ride, better traction in a straight line, Cheaper tires, as a rule more tire options, no worry of pot holes killing wheels ect.
In some cases larger wheels look better (within reason, not a fan of the massive wheel with rubber bands for tires at ALL).
Old 12-01-2014, 09:25 AM
forsyth793's Avatar
I never thought about the price of the tire. I guess they do make more 16" tires than 17 & 18's......
Old 12-01-2014, 09:26 AM
Texas_Ace's Avatar
Depends on the type of car. For trucks this is true, for sports cars 17" generally has one of the widest selections, at least for sports tires.
Old 12-06-2014, 12:59 AM
wyoming9's Avatar
Red face
The only real reason I could see is if you have several Toyota vehicles and want to run a standard wheel and tire combo for the whole fleet.
smooretahoe
08-14-2015 09:23 AM
Up&Down
08-05-2015 06:20 AM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
skoti89
07-06-2015 07:45 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Advantages of Larger Wheels?
