Adjusting the rear brakes
Old 03-03-2006, 06:08 AM
98runn'n's Avatar
Alright, I just rec'd my new Brembo rotors in the mail yesterday and new pads for the front. These are replacing my annoying warped rotors this weekend. I read somewhere on this sight that my rear brakes are probably not working that hard at all when I brake. My nose does go down when I hit the pedal, which makes me believe my fronts are doing all the work. So I ask how do I adjust the rears this weekend so that my brakes will all work together. Are there any write ups on this or pictures of where to adjust. Thanks.
Old 03-03-2006, 06:56 AM
MTL_4runner's Avatar
As long as your adjusters are working properly you can adjust the rears by backing up slowly (< 5 mph) and pulling up on the ebrake. You need to do this several times until the brakes feel properly adjusted.
Old 03-03-2006, 06:59 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Ditto, except I back up at about 10 mph then pump the e-brake hard and quick a few times (keep the button pushe in) and then keep repeating the process until the brakes feel better.
Old 03-03-2006, 11:32 AM
Gerdo's Avatar
Acording to the Haynes manual
"Back the vehicle up,making repeted stops, to actuate the self-adjusters, which work only when the vehicle is in reverse."
It doesn't say weather you use the parking brakes or the regular (service) brakes.
Old 03-03-2006, 11:39 AM
98runn'n's Avatar
Great, thanks guys. That will be easier than having to pull the tires and dink around with trying to manually adjust them. I'll try this later tonight.
Old 03-03-2006, 11:42 AM
HUTCHSTACO's Avatar
i think i will give that a shot on my truck too, never knew of that was true or not, now i know
Old 03-03-2006, 11:54 AM
Gerdo's Avatar
Also acording to Haynes
"On Tacoma models it should take 12 to 18 clicks to apply the parking system: on 4runners, the parking brake lever should apply the parking brake cables with 7 to 9 clicks."
One may assume, (if you have never adjusted/or had the parking brake cable adjusted), that if you have the appropiate amount of clicks then the rear brakes are probably close to set.
Old 03-03-2006, 12:01 PM
Jeffires's Avatar
Adjusting the brakes like this is effective, but sometimes after installing a new set of shoes or springs in the rear, you may have to turn the star adjusting wheel with a brake spoon. This is only after new hardware install, in scenarios that the brakes are so far out of adjustment, they do not catch properly to self adjust. This will usually be accompanied by slack in the parking brake.
Also if you have raised your truck slightly (like with add-a-leafs) the LSPV may need adjustment. I had to adjust mine after I had my springs re-arched and added to
06-01-2021 01:51 PM
87turboPA
07-12-2015 07:49 AM
garagespace
07-09-2015 08:37 AM
87turboPA
07-09-2015 05:58 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Adjusting the rear brakes
