Adding weight to improve traction
Location: Far western Kentucky (transplanted from central PA)
As capable as my 2000 SR5 is in the snow, I feel as if I'm not getting a good bite and that i'm "floating" on top instead. I have 265/70/16 REVO's and I'm running them at 33 psi all around. In the past, I used about 200 lbs of sand bags in the back which improved my bite somewhat, but I hate hauling the extra weight if I don't have to. Any suggestions?
Your tread is probably loading up with snow and losing its effectiveness. Short of buying a more aggresive set of tires I think the extra weight is your best bet.
a more narrow tire perhaps? Also, how much higher can you inflate the current tires keeping within their limits and wearing properly?
If I was in your situation, I'd fully air up my 6ply's to 50psi so as to break through any snow, but I dont live in a place that has that white, fluffy sand falling from the sky....lol
steve
steve
I agree with lowering the pressure for traction. Raising the pressure will make you more susceptible to hydroplaning and the back end breaking loose on ice patches.
oooooh you meant like 1" thick snow or so and then icy roads and whatnot.....
I thought you were driving on top of deep snowdrifts and not breaking through them to solid ground....hence the narrower tire and increased tire pressure comment.
ashamsuddin
17
01-13-2023 03:17 AM
kbpickens
10-02-2015 03:37 PM
JookUpVandetti
09-30-2015 08:58 AM
