Adding a sub amp to stock stereo?
Old 09-08-2008, 01:33 PM
Djlarroc's Avatar
I'm planning on using a line out converter. Where do you tap into the speaker wires? And which colors are rear left & right?
Old 09-08-2008, 02:15 PM
ozziesironmanoffroad's Avatar
if i remember right the purple and white are the left, brown and white are right. imnot sure though... look it up in the diagram....
Old 09-08-2008, 03:04 PM
Djlarroc's Avatar
I found the diagram about an hour ago or so http://www.modifiedlife.com/2000-toy...iring-diagram/ , but it's not exactly right. I've been checking the wires with a tester. So far, blue is constant, gray is acc, violet is illumination, and that's about it. I know brown is usually negative, so I have to figure out what's what in the remaining 8 wires.
theking11863
03-19-2016 09:36 PM
PNWrider
10-30-2015 08:14 AM
Esibnitsud
07-30-2015 08:19 PM
80Truck
07-24-2015 03:12 PM
msane99
07-17-2015 10:13 AM
Quick Reply: Adding a sub amp to stock stereo?
