Actual lift height for 2.5" ome
Old 03-16-2007, 07:25 PM
NG Crawler's Avatar
I bought a 2.5" lift. Ome 891s rear and ome and 881s in the front with KYB gas adjust shocks. I also got a 1"drop spacer and some stainless steel brakelines.Ok , will I get a full 2.5" out of the front and rear? I also ordered the panhard bracket and some top out spacers from steve s. Will my 4runner be level or what? I was going to go without the spacers up front but someone told me I needed to. Should i run the spacers? I just want my runner to be level when done. Any suggestions? Thanks Miles
Old 03-16-2007, 07:40 PM
BajaRunner's Avatar
Results vary, but when I did this lift I got 2" up front and 3.5 in the rear. Its slightly raked, but, nothing all that bad. Id personally run the top-out spacer on top though.
Old 03-16-2007, 07:51 PM
One_96TR4's Avatar
OME 890's are for the rear as well as the 891's. You sure it wasn't the 880's you got for up front?
Old 03-16-2007, 08:09 PM
NG Crawler's Avatar
woops
To be honest I dont remember what the front were. You are right though. I will have to check.
Old 03-17-2007, 04:33 AM
MTL_4runner's Avatar
I hope you didn't get 880's for up front or the rake will be horrendous. Even with 881's up front and 891's in the rear, you'll need alot of spacers to make the truck approach level. The amount of lift you'll get totally depends on the starting ride height of the truck which in turn depends on the year of the truck. On a 1997 4runner and assuming you don't have any heavy bumpers or carry any heavy tools around in the cargo area, you should see almost a full 3" in the rear from those 891's....I had 890's on mine and got a full 2.5" lift out of those.
Old 03-17-2007, 01:49 PM
k_southman's Avatar
881 got me 3" in the front
890 got me 5" in the back.
I had major sag in my stock springs.
Old 03-17-2007, 02:02 PM
I'll say!
Old 03-17-2007, 04:33 PM
etan's Avatar
yeah with 890's i got 4" higher after the sagging.
Miles... OME891's are for HD rigs. are you going to be towing or hauling a lot of load. i think its rated for a constant 250-300 lb load. maybe you should think about 890's or 906's if you're WORRIED ABOUT BEING LEVEL. if not there are many spacer options from full packing spacers to lesser top plate spacers to trim packing spacers to level out you're 4runner.
Old 03-17-2007, 07:35 PM
NG Crawler's Avatar
I will have to check in the morning...........
But I know the rears were 891s but I ll have to check on the fronts. I just want the vehicle to be level. I want no rake at all. I ordered front top out spacers and longer studs so that I won't have any rake but we will see. What is the ideal spring and shock setup?
Old 03-17-2007, 07:38 PM
NG Crawler's Avatar
hmm
I will not be towing or hauling anything around. I wont even have any front or rear bumpers(aftermarket) Just wanted to get a good suspension that would get me good flex and enough clearance for bigger tires. I hope it doesnt sit 4" high in the back!
Old 03-17-2007, 07:39 PM
NG Crawler's Avatar
coils???????????
Which coils will i need up front not to have any rake?
Old 03-18-2007, 06:20 AM
There are a few setups that will get you within 1/2" of level. Keep in mind you don't want it to sit truely level with no one in it because once you start loading it, the rear end will begin to look like it's sagging.
Here's what I'd recommend (front/back):
OME 881 / OME 906
Tundra coils / OME 890
Coilover such as SAW, Downey, King / OME 891 (this setup will be very stiff sitting level)
Old 03-18-2007, 01:34 PM
ozarks_Runner's Avatar
I never measured my rig before and after the lift to see how much I really got...but when I first put my 890's in the rear I had the front cranked all the way up, and I was still higher in the rear. After a couple weeks and adding 50-100lbs of gear it sits maybe 1/4-1/2" high in the rear with just me, and perfectly level with any passengers in the rear. I'd say I ended up with somewhere between 2.5-3".
Old 03-18-2007, 01:39 PM
NG Crawler's Avatar
Ok
I went to the shop and looked at the tags! The fronts are ome 881s and the rears are ome 890s. So now that I have the specs who has these coils and what did they do for you? I hope to get it together this week! We will see how thing go
Old 03-18-2007, 01:49 PM
k_southman's Avatar
As stated above:
I had major sag in my stock springs. I am very happy with the ride. The first 2 weeks were a bit harsh, however the ride seems to have smoothed. You will love the OME setup.
Old 03-18-2007, 02:52 PM
I went to the shop and looked at the tags! The fronts are ome 881s and the rears are ome 890s. So now that I have the specs who has these coils and what did they do for you? I hope to get it together this week! We will see how things go.
I had that exact combo on before I switched my 890's for 906's (due to the excessive rake). If you want pics of what it looks like, click on my sig. You're going to have about 1.25"+ of rake front to back with no spacers up front with those on your 97 4runner.
Old 03-18-2007, 05:30 PM
NG Crawler's Avatar
rake
Did you like the ride quality of the ome susp.? Is the 1.25" a big noticable
difference? I think Im going to order the spacers anyway.
Old 03-18-2007, 06:00 PM
BMWToyotaMan's Avatar
go for the toytec 3 inch ome lift kit, it comes with a topout spacer in front so its 3 inches front and back. Just be sure to get the diff drop.
Jeff
Old 03-18-2007, 09:18 PM
NG Crawler's Avatar
lifted
Jeff
Ive already bought the lift. Its ready to go! Im excited as hell but got towait
till wed. damnit.
Ive got the diff drop and the topout spacers and panhard bracket.
Flying91
45
04-11-2024 04:39 PM
nvdesertrunner
05-11-2020 08:18 PM
nickbeauregard
12
08-07-2015 06:04 AM
4Runnin2000
07-29-2015 06:09 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Actual lift height for 2.5" ome
