Acetone increases gas mileage?
http://pesn.com/2005/03/17/6900069_Acetone/
http://www.timebomb2000.com/vb/showthread.php?t=143848
Check out these links. What does everything think about this? Anyone ever tried it to see if it actually works without screwing up your engine?
first: if fuel milage could be improved that easily, don't you think that the car companies would have already done that, especially since the CAFE regulations are geting stricter.
second: the reason they give (helps fuel vaporization) is not valid. the fuel is already vaporized. if you're having problems vaporizing fuel then you need new injectors. and it would show up as a CEL. any unvaporized fuel would come out as increased hydrocarbons in the exhaust and the O2 sensor would see that and tell you something was wrong
third: acetone is great at disolving stuff, especially any rubber hoses/seals that it may pass through
i could go on, but i should get back to work. any time gas prices start to rise, all kinds of people start to adversite "secrets" that improve milage. the same thing happen during the oil crisis of the 70's. i'm about to write another rant about gas milage in this thread: https://www.yotatech.com/forums/f2/improved-gas-mileage-56008/ where i'll talk about how to save gas.
I love that - "If it actually improved blah blah blah, why don't they include it in blah blah blah?"
If ceramic composite rotors and pads stop faster, why aren't they standard equipment on all vehcile with a GVWR greater than 3,000 pounds?
If turbochargers and superchargers effectively add power, why aren't they standard on all engines?
If Goodyear Assurance Triple Treads with Run Flat are the best tire available, why aren't they standard on all cars?
Fuel is not VAPORIZED at the injector, it is ATOMIZED. Big difference. Atomization of fuel carries greater density than vaporized fuel. Gasoline HAS to be atomized. It will not burn efficiently if vaporized. If it were vaporized, the O2 to gas ratio would be too great and ignition would not occur.
Anyone care to guess what one of the ingredients of off-the-shelf radiator cleaner is? Acetone.
Originally Posted by Ehinfinity
mineral spirts and naptha, are also a home remedy for a fuel injector cleaner, not to say i would ever use it unless
eric
eric
i will try to address them as best as i can. instead of saying "if it actually improved blah blah blah, why don't they include it in blah blah blah", i should have been more specific. i probably should have said, "if it actually improved the customers perception blah blah blah at a cost lower than than the customer wants to pay then why don't they include it in blah blah blah"
supercharges: i don't have a good explanation, i think they should be standard equipment. but maybe it's just because it raises the price of a car more than the the percieved added benefit to the buyer.
so back to my original argument: (conspiricy theories aside) if fuel milage could be improved by 15-35% as the link says, and it cost less to buy the acetone and mix it with the fuel, then it would have been done already. my guess is that IF (and that's a big if) this did increase fuel milage, the costs associated do not even out. if they did, i'm sure there's a trucking company that already does this (granted, this is talking about gas and not diesel). or how about the oil companies that spend millions on chemists to develop the next gasoline additive so they can market their gas as better than their competitors? if adding a little acetone made milage that much better, then i'm sure there would be a oil company out there advertising "hey buy our fuel, you'll get better milage!" and they could charge a slight premium for the special fuel.
there is no magic thing out there that will make drastic fuel milage improvements - or maybe i should add: and costs associated with improving fuel milage are not offset by the cost of fuel saved (at today's fuel prices). with the market for cars so crowded, if a car company had something magical that would make their car get better milage (and still perform as a normal car), you can bet they'd do it. but in reality, any improvements would cost more money than is saved over the normal life of a car.
example: i drive 10,000 miles a year. if i use the low end estimate of my fuel milage (18mpg). then i burn about 560 galons of fuel a year. let's take a high end estimate of fuel prices: $3 a gallon. that's about $1700 a year in fuel. best case senario, the magic solution will double my fuel milage to 36mpg, i only save about $850 a year in fuel. think of any mod you could do your car that could double your fuel milage AND be cheap enough to be worth saving $70/month in fuel costs.
mike_d-
I should have clarified a few things, too. I got a little carried away as well.
yes, ceramic brakes are junk in cold. They are only truly effective when blister hot.
I have a question for you though...is acetone water soluable? I'm racking my brain trying to remember. If so, that would be an even greater reason NOT to put it in the gas tank. I'm thinking it is water soluable and that's why it's an ingredient in radiator cleaner. But, as many of us have seen on our V6s with HG issues, oil (petroleum) and antifreeze (water/glycol) do not mix well.
Also, isn't acetone (pure) lighter than gasoline/petroleum? If so, wouldn't seperation be a problem?
http://peswiki.com/index.php/Directo..._Fuel_Additive
Intersting it seems some people have tested it with varying effect (if you believe all you find on the internet)
fyi, here is a datasheet on acetone. it is water-soluble, in fact 1:1. given what it does to gummy residue, it's no surprise it's useful as a cleaner for various car parts, but i'd be very skeptical of burning it as an additive.
First these decrease the pumping losses, thereby increasing the efficiency and overall output of the motors. If you look at various foriegn automakers, and even some domestic, they are rapidly becoming more common (look at audi, just about every single motor has a turbo for these reasons). Second, they would be standard on every vehicle except that vehicle manufacturers don't have to use them to get the better fuel economy, so right now they're just offering them for the bonus of power. The more time passes, the more and more they will become standard. You can drop displacement, add boost, get better gas mileage, and equal power compared to a larger displaced less efficient motor. As for lag time, variable displacement turbos which are becoming more and more of the standard almost negate any lag time. and like previously said "the goal for cars is to put the cheapest stuff on there, and charge as much as you can for it." Sorry to hijack a little there and get on a tangent.
I wouldn't dare add that stuff to my truck, but I have used it as a cleaner.....
Originally Posted by hamstrungtaco
so all in all its not recommended
And Mike D, do you really think oil companies WANT to improve fuel economy?
DMG
Originally Posted by DMG
My tank has 2 ounces per 10 gallons acetone in it right now.
I would be willing to drink a glass of water with acetone in it in that ration. Nothing will happen to me, nothing can happen to the fuel systems like that website claims, and it will not influence MPG one bit.
At least you won't ever be able to prove to anyone even half intelligent that any change in MPG was the result of acetone.
One must be REALLY thick to buy into this blatant snakeoil sales pitch.
And this is who is behind the scam.
And this...
..means you will not see any gain, but you should not give up and buy some more to supposedly find that elusive "narrow peak effeciency" from the stuff they sell.
After having just a bit of remaining doubt allayed regarding potential harm to fuel sytem components....I decided to plunge ahead with my own testing.
I am happy to report that, at a ratio of 2.8oz. per 10 gallons of premium gasoline, I have enjoyed a 12mpg increase in efficiency in my Dodge Grand Caravan. Of course, in perspective, the high mileage engine was getting substandard mileage (16mpg with ethanol fuel) and the recent plug change and the addition of a pure petroleum oil additive (to control 'blow-by') are contributing factors. Regardless, the mileage now, at 28/29mpg seems to be giving the old wagon a new life....one I can only hope lasts awhile! The power increase is impressive as well. The engine fires up like a Goddard rocket when the key is turned and I couldn't be more pleased.....well ok, I admit that a set of Robert Krupa's firestorm sparkplugs to boot, might eke a bit more emotionalism out of me!
xtrampg.com - It's acetone! They advertise 30% increase in mileage with their additive, which they sell for $30/a case of 10, for 20 fill-ups.
REMEMBER:
In testing the additive in your own vehicle...the performance curve is steep, with a narrow peak efficiency...one definitely worth laborious determinative efforts, if needs be.
Regards,
M.R.
Regards,
M.R.
Originally Posted by 4RUNR
You do realize that that is a 1:640 ratio? Or 0.16%? That is one sixth of one percent.
Right now the mileage is about 17 mpg with 75% city 25% highway commute miles.
DMG
Originally Posted by ORB
I think some guy on TTORA said he was going to try it. I don't think I'd do it, but I'd be interested in the results...
