ABS Rotor and collar on axle help
Guys,
I had my wheel bearing fixed and i think they pressed the collar on too far. Same thing happened on the other side. The collar doesnt go all the way against the rotor. When it is like that, it doesn't seat on the inner axle tube seal like it should causing it to leak. Does anyone know the measurement for the collar?
Here is a pic:
Here is a pic:
There are actually 3 different space measurements depending on the vehicle and package. I dont know them offhand. We built 3 measuring tools that we just hold up the the axle when we are pressing on the collars. Best way I can tell you to do it is to put the axle in and then pull the abs sensor out and see if you can see the tone ring. When the tone ring is centered in that hole you know you have it right since that collar rests against it
Jcrawl94
10
10-24-2015 04:34 PM
klavender1
08-15-2015 01:51 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
