ABS ring install dimension needed!
Hi, working on a friends 2000 4runner V6, 4WD, limited. I am replacing the rear axle seals, wheel bearings and abs rings. I am in need of the proper dimension of how far to press the ABS ring and retainer onto the axle.
If possible please be specific on where exactly the dimension is measured from. From what i understand the dimension is generally from the hub face (where wheel mounts) to the inboard most edge of the retainer. It may be different for newer 4runners though, I am not sure, if it is please let me know. Thanks in advance!!!
When the bearing is in its final position, install the bearing lock to bear on the bearing. then the abs ring bears on the lock then another lock after the abs ring...from the outer face of the axle flange to the inside face of the abs ring is 122.2 +/- 1 mm. EDIT: why can't i attach pics?
