99Runner, heater problems - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-14-2007, 09:53 AM   #1 (permalink)
I've got an issues where every fall I have to take my runner in for it not blowing heat. It's usually a case where it blows almost but not quite luke warm heat. Barely enough to keep the ice off the windshield so long as you don't drive it...
Other times there is just flat out no heat.
Yet other times there will be rear heat but not front heat, or perhaps it'll just decide the defrosters aren't going to work today. Tomorrow it may work like it should, hot and all settings.
The dealership has replaced the thermostat, radiator, and heater core over the years. They have pulled the dash and examined the ducting and switches. Once they found a loose cable. It's now out of warranty as of about 4000 miles ago.
Anyone else have this problem? How did you fix it and what was it? I love my truck but this is an issue I'm getting tired of. I noticed that again, the thermostat doesn't rise but about 1/8th an inch above the top of the bottom line on the temp gauge. This is always the case it seems but isn't the thermostat since they ALWAYS replace that and it never solves it. I have sufficient coolant since it gets torn into, drained and replaced every winter by the dealer.
1999 Toyota 4Runner 4wd
3.4 V6
Automatic Trans
104,000 miles
Thanks,
Ub.
uberhiker is offline
Old 01-14-2007, 05:40 PM   #2 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Few questions for you first.....
1) Do you have electronic climate control on your 4runner?
2) Has the temp guage always read that low?
I had something very similar, but it turned out to be a bad thermostat and thorough coolant flush that finally solved the issue (not just a drain and fill like you usually get when work is performed). My issue may have been different which is why I asked the questions.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 01-14-2007, 11:57 PM   #3 (permalink)
1. No
2. No
3. Yea... I fixed it. Perhaps last time when the dealership messed with the cables in the dash they fixed it. Can't blame anyone but me this time, my coolant level was low, real low. I just assumed...
Thanks anyway, I've got hot heat now.
Old 01-15-2007, 05:47 AM   #4 (permalink)
You're lucky it didn't overheat if the coolant was that low.
In any case it sounds like you got it solved.
__________________
- Jamie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
99runner / fuel gauge TSB /Mileage question sharrack 95.5-2004 Tacomas & 96-2002 4Runners 4 01-21-2007 07:20 AM
heater core or valve problems? nieveparasiempre 95.5-2004 Tacomas & 96-2002 4Runners 2 12-02-2006 08:27 PM
heater problems john c Early Land Cruisers 9 12-08-2005 01:27 PM
2000 Tundra - Heater problems Daryl 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 9 12-01-2004 07:09 AM
Heater control problems OneTrickToy 95.5-2004 Tacomas & 96-2002 4Runners 4 03-06-2004 10:18 PM
2009 InternetBrands, Inc.
