99 Tacoma Starter will not shut off
Old 11-22-2007, 11:12 PM
tuancrown's Avatar
I have a 99 Tacoma V6.
Tonight, my tacoma will not shut off WITHOUT the key in. The starter kept turning the car over. So I'm sure that my starter is fried. But why did it just happened? So I had to pull the battery out (took the negative wire off the battery).
Does anybody know what the heck is my problems?
Is it the ignition switch?
In the morning I'm gonna check the key ignition switch and see if it's stuck. I can easily pull the the key in and out. It just happened randomly when I tried to park the truck.
PLEASE HELP!
Old 11-22-2007, 11:18 PM
superjoe83's Avatar
the same thing happened to mine, I'm 99% sure its the contacts in the starter, you can replace the contacts and plunger for under $20, or get a reman, i replaced the contacts in mine for $5 and its been a year so far, no issues.
there are tons of threads on this topic, try a search
Old 11-22-2007, 11:21 PM
tuancrown's Avatar
zhanks for the quick reply!
My question is it happen even without the key in the ignition? This happen to you also?
I did my search regarding the contacts on the system, which i plan to do tomorrow morning.
Staff
DeathCougar's Avatar
Starter is the problem. replace it, or repair it.
Staff
Mine has done the same thing even without the key in the ignition.
Old 11-22-2007, 11:28 PM
superjoe83's Avatar
pretty much, though before it stuck on i had problems with it clicking and not starting unless i cycled the key a few times (common contact problem)
then one day i started it and noticed after it started, the starter was still spinning!!! so i turned off the ignition and it kept cranking for about 5-10 sec then stopped by itself, by then i had the hood open and was at work getting the cable off....
Old 11-22-2007, 11:30 PM
tuancrown's Avatar
Damm...again I'm a Newbie to this forum.
I really appreciate your replys.
I 'm glad it's just the starter. I thought it would be a stuck ignition. Anyhow, I'm guessing I fried my starter? The starter was cranking for a good 2 minutes before i was able to find a 10mm wrench to take it off. So you guys think just fixing the contacts will fix it?
Or screw it, off to Autozone for a million dollar starter. =)
Old 11-22-2007, 11:32 PM
tuancrown's Avatar
That was happening to me too!! Just didn't have time to get around to fixing it. Again, thanks for your comment/info!
Old 11-22-2007, 11:33 PM
superjoe83's Avatar
if it ran for 2 min. it got very hot, in this case i would get a reman
Old 12-07-2007, 01:27 PM
tuancrown's Avatar
Thanks for the fix guys. I replace the dam starter. If I had been proactive, I couldn't just fixed the contacts. So instead of spending $20, I spent a $100. Well at least i have lifetime warrantee!
Old 12-08-2007, 08:16 PM
j-man's Avatar
mine started cranking one day as soon as i got into the car without even getting the key in the ignition - that was a trip - same thing = starter.
Old 12-09-2007, 12:59 AM
Adam F's Avatar
You'll need it! Most people I talk to have to replace the reman starter every couple of months.
Old 12-09-2007, 02:51 AM
KdF
KdF's Avatar
Just make sure you get a Nippon-Denso Starter. Keep the old one and rebuild it with the contacts and plunger. Then you have a spare.
ManzDaKlown24
08-22-2015 10:25 PM
Dakotaneu
08-15-2015 07:24 AM
norcal98
08-10-2015 06:20 AM
clok
08-01-2015 09:42 PM
ZONAYODA
07-13-2015 07:17 PM
Quick Reply: 99 Tacoma Starter will not shut off
