99 Suspension - YotaTech Forums
Go Back   >
99 Suspension
LinkBack Thread Tools Search this Thread
Old 05-17-2005, 10:32 PM   #1
964runner's Avatar
Talking 99 Suspension
First of all some of you may remember me from about 6 months ago when I had my 1996 4runner 2wd. I totaled that truck in a rearend colition with a car that had no brake lights. Now finally i got what i really wanted a 1999 4runner Sr5 4wd ill try and post some pics soon.
Anyways, I know there are alot of threads out there about third gen suspention but none seem to answer my question. I am running 285/75/R16 BFG tires on stock suspention right now (the running boards are off so no rubbing) I would like to fit 35 inch tires and have a wide stance. I was thinking of doing the sway-a-way race runner suspention in front with downey coils in back and having a 3 inch body lift. I would also use 1.5 wheel spacers. Is anyone running this setup and how do they like it or is there a better or more cost effective setup out there. Let me know any info you have to offer about 3rd gen suspetion, all help is appreciated.
964runner is offline   Reply With Quote
Old 05-17-2005, 10:51 PM   #2
BajaRunner's Avatar
Cost effective: Revtek 3" suspension lift and 3" body lift.
Definetly somethign I wouldnt do... but, you could run 35s. Your most likely going to wan to re-gear as well. 35's will be slow from the get-go .
You could also just do a 6" suspension lift...trailmaster, fabtech and tuff country make drop braket lifts . but are $1500
BajaRunner is offline   Reply With Quote
Old 05-17-2005, 11:05 PM   #3
964runner's Avatar
I have never seen any trailmaster,tuff country etc. lifts for 3rd gens. Do you have a link. How does a drop bracket lift work
Old 05-18-2005, 06:10 AM   #4
Jonathan's Avatar
Quote:
Those kits will only work for the front, as they are designed for the Tacoma. The Tacoma has leafs in the rear so you would have to come up with some sort of lift for the rear.
Jonathan is offline   Reply With Quote
Old 05-19-2005, 10:49 PM   #5
964runner's Avatar
Anyone else have any sugestions
Old 05-19-2005, 11:43 PM   #6
BajaRunner's Avatar
Well, just to let you know... I am doing a Trailmaster install on my 3rd gen tomorrow actually. I'll have more pictures, but, here is my current thread about it now.
/f31/i-got-trailmaster-kit-pix-59015/
I'll be doing a leaf spring swap in the next month or two, but, until then I'll be using OME rear coils + 2" cornfed spacers.
Old 05-20-2005, 12:38 AM   #7
to fit 35's and still be able to stuff them in the wheel well you have to run 16x8 rims with stock backspacing.
If it's your daily driver, stay away from wheel spacers
BruceTS is offline   Reply With Quote
Old 05-20-2005, 11:53 PM   #8
964runner's Avatar
Bruce- it is my daily.. what are the negitive effects of the spacer?
SC4runner- That setup sound nice, let me know how it turns out, if it works good maybe you could give me some guideance on how to put that on my truck
thanks to everyone for your help
Old 05-21-2005, 09:00 AM   #9
HOJU's Avatar
I've got an OME lift, 2" roger brown bl kit, wheel spacers from marlin crawler and it's my DD driver.... haven't had any probs. with my 35's yet-
HOJU is offline   Reply With Quote
Distance vertically between oil pan and highest part of axle housing? live4soccer7 84-85 Trucks & 4Runners 3 05-11-2016 07:52 PM
1990 2wd 22r to sbc or sbc questions Thamuel_ Domestic Swaps 1 10-03-2015 12:15 PM
Lifting my 83 some questions ktm192k Pre 84 Trucks 1 10-01-2015 09:47 AM
Newb looking to do an ENTIRE drivetrain conversion on 2gen 4Runner TheBFA Solid Axle Swaps, All Years 6 10-01-2015 01:18 AM
BLAZELAND LT IN 87 4RUNNER INSTALLED / CV comment and Question. JookUpVandetti 86-95 Trucks & 4Runners 10 09-30-2015 09:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
