99 Ltd - need help with my power moonroof
My moonroof doesn't quite come flush with the roof sheet metal on the front edge of the roof when you close it. It sits about a 1/4 inch below the edge all along the front.
*** EDIT if you've removed the moonroof assembly before, please let me know!*****
Other than that it functions fine but it's collecting water when it rains hard which is a pain! It appears there is something that should let the sunroof rise up as it closes on the front side.
Can someone take some pics of their power moonroof with it open? (close pics of the tracks maybe?)
thnx fellas,
lbrowne
thnx fellas,
lbrowne
that crap is all adjustable
I don't have the diagrams with me but basically
open it up and poke around you will find the things
and partz that can adjust it. you can adjust forward, aft, side to side.
Since I have the headliner out anyways I wanted to remove the sunrood assembly - but the mother^!%&#%! is held by something that lines up with the center pillar between the front and back door on the passenger side. I have all the bolts out and the sunroof assemble wants to drop down except in this one spot.
Anyone take the assembly out before?
kinda sorta
the bolts accessible from under the headliner are to bolt the thing in, not adjust
the 'adjustments' are all from the top. pull out some of the
covering plastic and you can access the drive rail adjustment bolts
I knew those bolts only hold the sunroof in, but I have a buckle in my sheetmetal that I'm going to fix real quick since I already had the headliner out. (and it's easier to get at with the sunroof removed.
But this clip or whatever it is is keeping me from removing the whole assembly. This part should be for another thread.
I appreciate the suggestion on the adjustment btw! Thanks, lbrowne
dang. again, my diagrams are home while I surf here w/o diagrams
I might be able to take a jpg from the pdf and paste it up but alas,
no file here now....won't be able to till tuesday
Thanks for the pdfs! Much appreciated.
However it makes no mention of this clip or whatever it is that is holding this darn thing in place. I have all the bolts outand the whole darn thing wants to drop out except something near the passenger side B-pillar is keeping it up!! argh!
delmert
09-30-2015 04:34 PM
