99 Limited Need Front Mud Flaps
Old 11-21-2011, 05:39 PM
hurricanes99's Avatar
Title says it all...I removed the running boards on my 99 Limited last year and I'm getting a sand blasted effect on the rocker panels. Any suggestion? I have searched and searched. Just bought some Highland Contura's because they claimed to fit the 99 Limited with flares, but they don't fit at all. Any ideas?
Old 11-21-2011, 06:24 PM
87 Deathtrap's Avatar
Partsgeek has rubber or aluminum diamond tread. They are universal fit (or don't fit) though. At $14 for the rubber ones they may be worth a try.
http://www.partsgeek.com/catalog/199...mud_flaps.html
Old 11-22-2011, 06:48 AM
MadCityRich's Avatar
Rumor has it that Tacoma mudflaps can work. Apparently two of the mounting holes line up with 4Runner fender lining screws, with a need to cut into the mudflap for a third screw.
I have no first hand knowledge of this, but it's a topic I return to from time to time in anticipation of installing sliders. If you try this solution or find another, please post the results. I'll do the same when I find a solution.
MadCityRich
02 4Runner Ltd
Old 11-22-2011, 07:23 AM
Running4life's Avatar
What is the part number of the Highland Contura's? Is it 11051. I believe that is the model that fit with one minor trim needed on the pinch weld at the bottom.
06-01-2021 01:51 PM
djpg2000
11-11-2020 04:56 AM
Ironmike4x4
02-03-2016 11:13 AM
coffey50
07-28-2015 10:55 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: 99 Limited Need Front Mud Flaps
