99 4runner wobble/shakes?
Ok so I'm not the most mechanically sound person on this forum I'll do my best to explain my problem. I'm experiencing pretty bad wobbles and shakes when my 4runner is in gear and slowing down. When im not applying the throttle and its in gear it feels like the back end starts shaking or like a jerky bumping. If I drop the 4runner into neutral it stops completely. I just had the tires replaced so I dont believe this is a unbalanced tire or anything of that sort. Any help would be appreciated..
Pretty hard call to make .
Just when did this start ? After the tires work was done??
How many miles ??
Could be a ujoint getting worse .
Might be worn suspension parts broken shock mount .
Transmission mount?
Just how bad does it shake ??
This happens from all speeds and not just within a certain range??
How many miles ??
Transmission mount?
How many miles ??
Transmission mount?
How many miles ??
Transmission mount?
Does it happen in slow speeds as well? If so, take off the rear driveline, then drive in 4WD so that only the front wheels are driving the truck. Does the shaking/wobble still happen?
Flying91
45
04-11-2024 04:39 PM
BeMiceElf
10-10-2015 09:40 PM
