99 4runner: Timing chain OR belt?
Old 04-08-2007, 10:00 AM
NorCalJ's Avatar
99 4runner v6
does this thing have timing chain or belt?
if it is a belt setup I better change it! What else needs to be changed at the same time?
water pump, tensioner, anything else?
Old 04-08-2007, 10:01 AM
BajaRunner's Avatar
Its got a belt.
When your in there, do everything you can.
Heres a good link on how to do it
http://www.4x4wire.com/toyota/maintenance/timing_belt/
Old 04-08-2007, 02:13 PM
habanero's Avatar
I had all the likely possibilities, changed what was needed, returned the rest. Water pump had a mild leak, seems this is kind of common? One of the pulleys bearings wasn't real bad but didn't sound smooth enough.
Belts and hoses. Coolant.
Easy cept'n that darned tensioner, but I did it only with basic tools, a tool to hold the crank pulley still to get the bolt out and a torque wrench that could do the job.
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
razorman8669
07-12-2015 12:13 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 99 4runner: Timing chain OR belt?
