99 4Runner shakes when taking off in 1st Gear and Reverse- Suggestions?
Old 10-23-2014, 11:18 AM
touchuptech's Avatar
I have a 99 4runner that shakes only on takeoff in first gear and reverse.new mounts,shocks,anyone else have this problem?
Old 10-30-2014, 05:40 PM
Just_Me69's Avatar
I know that first and reverse share the same clutch band. Mine takes about half of a second to shift into either from park or neutral. I was once younger and way dumber than I am now.
I'm pretty sure it's the deepest band and drum in the transmission case. You might wanna give that a look.
Old 11-04-2014, 03:38 PM
Junkyard Dog's Avatar
Okay, if you hold down the brake pedal firmly and accelerate the engine to about 1500rpm IN GEAR, does it still shake? Doing this will help you a lot as far as trying to figure out whether this is an engine problem or a transmission/driveline problem. If it shakes without the vehicle even moving, then you more than likely have a misfire issue.
Old 11-06-2014, 06:31 PM
Just_Me69's Avatar
Damn. I thought there would be more here. A misfire would also come up at cruising speed, probably going uphill. I once had a tough to diagnose misfire on a mustang with a 3.0. Turned out to be a cracked plug. It would only do it just above 45 after the torque convertor locked up.
voiddweller
19
05-02-2016 09:10 PM
mtrdrms
07-17-2015 02:23 PM
YotaGreenhorn
06-27-2015 07:00 AM
ACZR
06-23-2015 07:55 PM
saphirekosmos
06-22-2015 10:26 AM
Quick Reply: 99 4Runner shakes when taking off in 1st Gear and Reverse- Suggestions?
