99 4runner LTD, hesitates when hitting the gas
Old 03-12-2004, 02:49 PM
sqzdog's Avatar
99 4 runner LTD, 79,000 miles. with auto. When I hit the gas, it seems to hesitate. Going down the road at about 25, I let off the gas, hit it and it still seems to hesitate. I used to have a 96 4 runner with 5speed (manual) It didn't do this and it had over 100k on it. Any ideas? :pat:
Old 03-12-2004, 03:39 PM
My99's Avatar
Start with the obvious - plugs and wires. If it still hesitates, assume it could be a fuel problem... fuel pump, or a malfunctioning injector. Could be you have an air leak too. Check all your intake plumbing and make sure it's all good and tight with no leaks.
Old 03-13-2004, 06:48 AM
swerks's Avatar
check your mass air flow sensor, try cleaning it along with your throtle body or you may need to replace it.( I had to ) but I was getting a check engine light.
Charecter1
11-06-2023 10:08 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Jnkml
07-06-2015 01:20 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 99 4runner LTD, hesitates when hitting the gas
