99 4Runner Limited 4x4 front lift help needed
I've got a 99 4Runner Limited 4x4 supercharged that I want to level up the front to the back.
It never sat totally level since I got it.
It used to have the following suspension on it with ear raked up higher;
Front
Stock tall 99 Limited coils on OEM struts
ToyTec 3" spacer lift
Diff Drop kit
Rear
OME 891 coils
Monroe Air shocks (set at 10#)
Now it has the following suspension on it;
Front
2004 TRD Tundra 4x4 front coils with new Gabriel Gas struts
ToyTec topout spacer - 1/2"
Diff Drop kit
Rear
OME 891 coils
The front still sits lower then the rear. I also have an ARB Sahara front winch bumper with a Mile Marker 9500# winch on the front. I think the both of them probably weigh 200#.
I measured the front from center of hub to the limited flare lower corner and it was 22 1/8".
The rear measured from center of hub to the limited flare lower corner and it was 23 1/8".
I was researching some ideas to level it up and the only things I can think of is;
1. Put OME 883 coils up front with maybe the ToyTec 1/2" topout spacer.
2. Put ToyTec/Eibach 3" front coils in that have a 620 # weight rating to them.
3. Find a 1" topout spacer to add to the top to get the extra 1" I need to get this 4Runner leveled up.
I just want some ideas from others on here that probably has messed with different combinations to get their 4Runner to sit level.
Thanks,
Doug
Front
Diff Drop kit
Rear
OME 891 coils
Front
Diff Drop kit
Rear
OME 891 coils
Thanks,
Doug
I'm just getting a set of Tundra 5100 adjustables so I can get better ride quality up front since I have the Sahara ARB bumper and MM 9500# winch, and I can adjust the ride height of the front of my 4Runner.
6th Gear
19
12-10-2019 07:31 AM
88Toy
7
06-17-2015 09:40 AM
