99 4 runner with issues
Old 02-18-2009, 05:04 AM
b/s rules's Avatar
i'm having problems with her 99 4runner, its got a real bad miss at about 50mph. we thought it was a coil pack so had it checked out and thats not the problem. the plugs look good. we had it scanned and it's coming up as a misfire on the #6 cylinder. could it be an injector or plug wire? i'm at a lose here so any help would be "pre-shaded" it's got the 3.4 v6 in it with 165k miles
Old 02-18-2009, 06:01 AM
okie81's Avatar
You could check the resistance in the plug wire with a voltmeter to rule that out
Old 02-18-2009, 06:15 AM
rbh261's Avatar
Sounds familiar. Read this https://www.yotatech.com/forums/f2/c...06/index6.html
Old 02-18-2009, 07:16 AM
b/s rules's Avatar
the plug wires are my next guess, i'm just hoping it's nothing to major
Old 02-18-2009, 07:25 AM
Potomacduck's Avatar
At 150,000 my 4Runner wanted a new MAF sensor and an oxygen sensor. That improved things a lot.
Old 02-18-2009, 08:30 AM
b/s rules's Avatar
she had that changed at about 145k, so i'm hoping thats not the problem. i'm going to take it and have new plugs and wires installed asap. crossing my fingers that takes care of the problem. we scanned it once and it came up as a misfire on #6, so we moved the coil pack to #4, the problem was still there scanned again and still came up as a misfire on the #6. so i think that eliminated the coil pack being bad.
Old 02-18-2009, 04:09 PM
wjwerdna's Avatar
obviously, check wires (run it at night, and look for sparks between wires/block)
other than that I am useless on help, sorry
sorta related, if it is purely related to RPM, check main crank bolt (the one that holds on crank pulley), mine came loose and was causing missing at 4200-4300 rpm, but no CEL
voiddweller
19
05-02-2016 09:10 PM
TNRunner88
07-01-2015 08:00 PM
WI Girl
06-25-2015 03:45 AM
bobbybouche
06-18-2015 10:22 AM
Quick Reply: 99 4 runner with issues
