| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
99 3.4 weird grinding noise and water on drivers side?
#2 (permalink) |
The water pump is where I would start.
__________________
Just my thought. 96 4runner SR5, 3.4, Auto, B&M trans cooler, H4 H.I.D. conversion Sway-A-Way/O.M.E. |
#3 (permalink) |
you have the timeing belt replaced yet ? if not now would be a good time
#4 (permalink) |
There is also a coolant hose that runs to the oil cooler in that location. I had to replace mine about that mileage.
__________________
'00 SR5, "Highlander" Dual Cases, Aisin Hubs, E-Lock'd, Cryo'd, Chromo'd, ARB'd, 315's, Sonoran Steel Bumper, Lift & UCA's, 4 Crawl 1" BL, Armored...etc. F-Toy #081 in progress Dual Cases, 30 Splines, 5.71's, E-lockers, Hydro-Assist, 37's, DOM Hendrix Chassis, 80Proof, ORS, Sonoran Steel...etc. |
#5 (permalink) |
Well I ran it by my friends shop today and he said he was positive it was the water pump. I am dropping it off to him on monday for a new water pump and timing belt. Thanks for the help.
Justin |
#6 (permalink) |
at 88k miles? Really? my 4runner had the first one changed at 131k
__________________
1996 Toyota 4runner Green - Yakima Rack - 4WD - Deckplate Mod - ISR Mod |
#7 (permalink) | ||
Quote:
Though Stepdads wasn't changed till 120K when he had it in for an over haul before our trip to VA (We were going to do towing and such so while his was in the shop, I was in the driveway getting fluids changed putting in my K&N and making sure everything else was checked so I could tow the trailer and take the dog so they could have room for there stuff, since i would be the only one in my rig....which was very nice) But back to topic... I do believe every 60k is toyota recommended...
__________________
Avdian (Avy, Av, Eddie are some nicknames)
The Reigning Tess - 97' 4Runner SR5 V6 4WD Auto My Life As Perfectly Described By Fireteacher: Quote:
#8 (permalink) |
The timing belt interval is 90K miles.
__________________
Lance 2001 4Runner Limited 4X4 -- 315/75R16 MT/Rs | MT Classic IIs | Dual ARBs/4.88s | (F) 5125/Tundra Coils (R) 5125/LC Coils | 4Crawler 1.5" BL | Aisin Manual Hubs | Slee Sliders | Sonoran Steel Rear Bumper | TJM T-15 w/ Warn M8000 2004 Land Cruiser -- OME Medium Lift | Nitto Terra Grapplers |
#9 (permalink) |
YotaFun and Bighead are actually both right. The story is that when Toyota first came out with the 5VZ, the timing belt durability was such that it required a conservative change interval of 60k miles and thus that was what was recommended in the maintenance schedule. As technology for the belts improved, the recommended mileage was extended to 90k miles. Thus if you change your timing belt today, you can now safely use the 90k mile interval (unless your vehicle was made between 96-98 and you are still on your first timing belt somehow or it was changed duing that period).
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Funny ticking noise coming from the drivers side rear... | Starbuck3733T | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 06-23-2007 08:14 PM |
| Grinding noise from the drivers front.... 85 Pickup | DBSS_Gohan | 84-85 Trucks & 4Runners | 5 | 03-01-2007 07:07 AM |
| Awful grinding noise coming from Driver side wheel any suggestions??? | ivanr | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-09-2007 02:02 PM |
| Funny noise from front drivers side wheel | Biohazard | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 05-10-2006 07:52 PM |
| weird grinding noise from rear end | dirtypuke | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-21-2005 02:45 PM |
