99-02 Headlight Swap Questions?
I am almost ready to do the 99+ headlight upgrade, but I was wondering if it is possible to use the frame from the old headlight on to the 99+ headlight? If it is, how hard is it and how long would it take?
I am wondering the same, how much the swap would be, and would it be a direct replacement or would you have to make modifications?
Vato when you find out please let me know. Gracias
i'm 99% sure it's a direct swap (someone confirm), you dont even have to reaim the headlights. jason burtman has a writeup on his page. good luck and happy holidays.
The 99+ headlight upgrade is a direct replacement on to the 96-98's. About my question SMR4Runner answered my question about using the frame from the 96-98 headlight and use it on the 99+ headlight. He says its a direct swap and the hardest part is removing the headlights.
Headlight swap
Let me know if you guys need headlights I will give you the hook up on them. I have them in stock and can ship to you immediatley for a small donation.
Halla!
Todd
Halla!
Todd
How much would it be to buy 2 new clear headlamps without the basket that holds them?
Would you be able to ship to Canada?
and also....do they new headlamps perform better or do they just look better?
I think mine performed a little better. I think they allow more light to hit the road. I dont know if you can get the headlights without the mounts though. When I ordered mine they came with the mounts.
From what I heard, there is a 15-25% increase in better lighting. You don't have to order the frame/baskets when ordering the headlights because the frames/baskets are interchangeable between the headlights. I am using the frames/baskets from the 96-98 headlights on to the 99+ headlights.
Originally posted by TOR
Just the headlight assemblies here.
81170-35300 $124.17
81130-35320 $124.17
I have them in stock ladies and gentlemen, ALL DAY LONG!
Todd
81170-35300 $124.17
81130-35320 $124.17
Todd
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
02, 4runner, 8113035320, 8117035300, 96, 97, 99, clear, conversion, headlight, headlights, swap, swapping, tacoma, tacomas, toyota
