98 Tacoma TRD rear end problems
Old 05-03-2012, 01:25 PM
LuckyStrike's Avatar
Hey folks, just bought a 98 Tacoma TRD, and unfortunately I am having some rear end issues.
Aside from the whining noise I hear on deceleration, the Rear Diff Lock light on the dash seems to come on whenever it wants to, and I am afraid that my rear is locking without my willingly engaging it. SO my question is...
Does this light mean the locker is actually engaging even though I am NOT pushing the button, and could this be the cause of the noise in my rear end? Also I found the right axle seal to be leaking, so thus far I suspect a worn out bearing to be the cause of the noise, the question is which one. But I thought perhaps a possible rear diff lock malfunction could be related to the noise. Like I said, a whining on deceleration. Thanks all. Haven't gotten a chance to take it apart though, college gets in the way!
Old 05-03-2012, 05:36 PM
jbtvt's Avatar
No the light does not necessarily mean the diff lock is engaging, I've seen them do that when they malfunction also. If a seal is leaking you are quite possibly running low on oil and destroying your 3rd member. 5 minutes to check or a $200+ part, your call.
Old 05-03-2012, 06:15 PM
Yeah, already filled the oil back up, but who knows how long the previous owner was running with it low on oil.
Old 05-15-2012, 03:13 PM
Well I finally got around to taking the axles out to change the seals. I took the backing plate off with the axle, and I noticed that it had a little play in it, I could wiggle it where it sits on the axle.
This has me a little worried that the wheel bearings need changing, is this wiggle normal? Also, how would I remove the backing plate from the axle, it seems pretty stuck on there. Thanks.
Old 05-16-2012, 02:49 AM
jbtvt's Avatar
I just went through this with a Ford. My DD Yota has no noticeable play, other Yotas I've owned have. If it's a cone bearing, as in most or all fronts, no play is acceptable, if it is a roller bearing/c-clip aasembly (which I belive yours would be, confirm with FSM) you can have a little play. See final post at https://www.yotatech.com/forums/f116...-video-237698/
Jmiller1023
23
08-06-2015 07:03 PM
red88toy
11
08-03-2015 07:47 PM
bigblue82
10
07-06-2015 08:27 AM
merc1100sc
06-26-2015 05:24 PM
Quick Reply: 98 Tacoma TRD rear end problems
