98 Tacoma Cylinder 5 Misfire
Old 07-18-2013, 11:22 AM
davestarcher's Avatar
I had the same problem with the same P0305 code on my 2000 4Runner with 5VZFE. I replaced the coil and spark plug with no luck. Then I read this thread and tested the fuel injector to find a resistance of about 90 Ohms. I replaced the injector and now it's running great. This forum really helped a lot.
Old 08-12-2013, 10:50 AM
Austin Marr's Avatar
I am having this same issue on cyl 3. Going to test the resistance OHM's on the injector to verify. I have a couple of questions in regards to the actual testing part of it. What do i set my volt meter to? also, do i place the volt meter in the female end of the electrical connector that is tied into the harness or do i put it on the injector prongs itself? also, do i test it with the ignition in the "On" position or does it have to be running? thanks guys! yotatech wins!
Old 08-12-2013, 04:48 PM
Derp.....never mind it won't run with the intake pulled off like that. Anyway I measured the resistance and its a bad injector! I vote sticky this thread!!!
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
256mbaker
07-31-2015 06:45 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: 98 Tacoma Cylinder 5 Misfire
