Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
98' Taco 4cyl Rear Third Member R/P ?
looked at my buddy's 2.7L 1998 Taco-
The Taco third has better gound clearance at the u-joint. I was wondering if it was an 8" like the earlier trucks/runners, and if the housings were interchangeable? The unit would make front drive line angles better on SAS'd rigs, and might be cheaper to get than a true hi-pinion-------- later |
| Sponsored Links |
#2 (permalink) |
if the drain plug is on the right side, i believe that it is the 8.25" diff. the only tacomas that have the 8" diff have the E-Locker, so if he has the E-Locker then he has the 8". otherwise it should be the 8.25" someone correct me if i am wrong
-Casey |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 63" chevy rear springs on 98 taco? | alanbobalan | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 02-28-2006 01:00 PM |
| bilstein 1500 shocks on stock 98 4x4 taco rear end? | alanbobalan | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 02-15-2006 07:10 PM |
| v6 or 4cyl third member in the rear | cherokeechief79 | Offroad Tech | 3 | 01-03-2006 12:38 PM |
| Will a taco 3rd member fit a 1999 2wd 4runner rear | Blackulua | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 04-01-2004 03:04 AM |
| rear diff lock mod 98 taco question | 505taco | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 08-31-2003 11:49 AM |
