98 4Runner Turn Signal Causes Headlights to Go Off
Hello,
I've searched afor nd found a couple of folks who had a similar problem with their 98 4Runners, but havent seen a definitive solution.
The problem is that I can get my headlights to go off by applying downward pressure on the turn signal (i.e. making a left turn). Probably a bad contact somewhere in the chain, but before I start disassembling the whole steering wheel column, I'm wondering if anyone's had a similar issue and fixed it.
If not, does anyone know of a good thread that describes how to take the steering column apart and remove the turn signal lever assembly?
Thanks, and regards.
-Ted
-Ted
ted,
in all my time here, this is the first time i've heard of something like this.
to remove the steering wheel cover column, turn the ignition into position II (i.e. to the point where the power steering pump is activated) and turn the steering wheel to the right until you can see a philips head screw. turn the other way and remove the other screw. the cover then can be easily unsnapped apart.
bob
bob
Originally Posted by Bob_98SR5
ted,
bob
bob
https://www.yotatech.com/forums/f2/turn-signal-problem-40605/
https://www.yotatech.com/forums/f2/headlight-flickers-22780/
maybe this is the same problem you have??
https://www.yotatech.com/forums/f2/dead-spot-your-head-light-switch-ive-got-your-fix-72134/
I just hope you have much more luck than I do. I've filed the contacts, greased them, and even freaking soldered them but I still have the stinking problem. I'm considering going back and just taking bare wires and soldering them to the contacts, but for the trouble, I might as well buy a new one. $200 from the stealership seems a little bit steep. I do know this is a common occurance for the 98 4Rs so I'm wondering if there may possibly be a TSB or something for this? If not then we should make complaints to Toyota Company and get a TSB set up for it.
how many miles do all of yall have?? this has never happened to me...and i really hope it doesnt start....
EDIT: i guess this isnt a problem that would grow as mileage increases is it...
Originally Posted by tedp
Hi Bob -- thanks for the reply, here's links to the threads I was referring to:
https://www.yotatech.com/forums/showthread.php?t=40605
https://www.yotatech.com/forums/showthread.php?t=22780
ah, i forgot to mention that htere is a screw on the bottom steering cover
bob
I've got around 121K on my clock, but it started happening around 90K miles. I'm tired of fooling with the thing. I am kinda curious though since it seems like only the '98 4Rs have this problems than any other year models *or at least from what I've seen here*.
Occasionally mine will kick the headlights off momentarily after making a left turn and straightening out again. When the turn signal stick automatically clicks back into the 'normal' position, the lights cut out for a second. This is a 97.
06-01-2021 01:51 PM
Suprarossa
07-06-2015 05:21 AM
