'98 4Runner Diesel 4x4
1998 V4 4Runner Turbo Diesel 4x4
I bought my 4Runner in Panama and drove it back home but I can't find any parts for it here in the States. Toyota said they cant order the parts because they arent allowed. something about a trade agreement. Everywhere else I try can't believe there are diesel 4runners until I show them, and no one has parts for my engine.
I need a new water pump and timing belt. I cant drive it, it is overheating real bad.
I hope I can find the parts in the states, otherwise I'll have to get them shipped from panama. anyone else have this problem or the solution?
its not registered in the states, I havent even tried yet, just bought insurance when I came in from mexico and driving to the east coast. I'm stuck here until I can get the parts.
Try one of the eBay international sites. I would start with Canada then try the UK.
Here's one I found on eBay.ca:
http://cgi.ebay.ca/89-01-Toyota-Dyna...item45f3b7f61e
Not sure if its the right one, contact the seller he may be able to get you the right parts.
Find out which other Toyota models they installed that engine in. Start searching under those models.
Also try Australian parts suppliers, they have a HUGE Toyota diesel market in Australia.
There is no VIN number, just these numbers. I know I can get parts from Panama faster than Australia but I hope to find the water pump here in the states so I can get home to South Carolina. I'm brokendown in Texas.
if you get no luck over the water try
www.roughtrax4x4.com
ive purchased plenty of stuff from them for my diesel everything is top quality
we get very little petrol 3rd gen's over here nearly all are diesels heres mine (desert dune) and the bro's (black)
http://www.roughtrax4x4.com/?doc=16&cid=179&vid=548
I found this water pump on that roughtrax UK site. Maybe this is the right part, I emailed them, waiting to hear back. It says it is for the 1KZTE but my chassis plate just says 1KZT
is a 1KZTE the same as a 1KZT ? maybe the E just stands for engine? (forgive my ignorrance)
I think this Hilux Surf is the same engine as my 4Runner...
http://www.roughtrax4x4.com/index.php?doc=11&cid=129
http://www.toyotadiesel.com/forums/s...highlight=1kzt
yea you are right, according to this thread, my 4Runner is a 1KZ-T, it has a mechancal pump and does not have an EFI. but maybe that is the only difference in the engines and they take the same water pump & belts....
http://www.cruiserparts.net/shop/ind...oducts_id=1144
I searched "1KZ-T water pump" on Google... $159, in stock, located in Sullivan New Hampshire.
thanks barrell roll, lol at pic...
I will call that place in the morning, along with a few other places, make sure I get the right part for my 4Runner. all the water pumps I found today have been specifically for Land Cruiser, Hi-Lux, and Surfs. I will make an order tommorow for sure, either within the States or outside the country.
I dug around. The E in this case means electronic control on the injection pump as opposed to straight mechanical--not quite EFI. Both use the same water pump OEM (Toyota) 16100-69356. In the UK suppliers call it J1512078. Here's one:
http://www.onlineautomotive.co.uk/Pr...ehicleID=28159
Canadian dealers may have access to this part but I could not find a source other than UK or Japan. You might try calling a Canadian dealer asking for a 93-96 LandCruiser with 3.0 L diesel engine (1KZT). part # 16100-69356. I doubt you can find it in US unless you get lucky.
EDIT: Dang, how did I miss Sullivan, NH. Nice, BarrelRoll...
thanks for the help Durk, I will check it out asap
the part in Sullivan, NH is 16100-69355 / Hi-Lux
the part you found Durk is 16100-69356 / LandCruiser
(different part numbers)
I'll call around tomorrow & find which is correct for a '98 4Runner
