98 4Runner 4WD - Gas pedal vibrates
Hi Guys,
Just had some work done on my 4runner. I was seeing some oil leaks on the engine block. Based on yotatech community input I had my valve cover gaskets replaced. Also had the mechanic replace my drive belts (except for timing) and change spark plugs and wires.
When I drove out of the shop I noticed that the gas pedal vibrates upon acceleration. I do plan to take it back to the same mechanic, but it might not be for another couple of days.
Do you have any idea what could be causing the gas pedal vibration. It is more obvious when I accelerate from stop position or go over 50.
Thanks for any input!
Road Bull
10-10-2015 04:55 PM
Jnkml
07-06-2015 01:20 PM
