98 4 runner, clutch pedal popping/squeaking!!
Hi everyone!! B4 I get bashed I know all about the clutch squeak thread and so forth, but I read through the entire thing and couldnt find anything concrete on what mine was doing compared to everyone elses...
Anyhow, I do have the famous squeak when pushing the clutch pedal down but mine makes a popping sound when the pedal is pressed about 1/2 to 3/4 of the way down(not all the time, but about 1/10 times the pedal is pushed)... Is this a common thing too with the pedal problems that everyone has?? This sound would resemble an ankle or knuckle popping/cracking sound...It didnt look like these trucks had clutch pedal bracket problems from what I read...Do I just need to do the spring mod to clear up this type of symtom as well???? thanks everyone..
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
i bet it's just the stock spring binding up then popping. i'd just do the mod and you'll probably experience a nicer pedal feel. i had the pedal squeak when i first got the 4runner a year ago, and switched out the stock spring for a linear spring from carquest. it was $3!
still have the recoil- now without the squeak.
I have a pretty noticeable squeak as well but mine isn't from inside the car it is coming from the boot on the side of the actual transmission under the car. I don't quite what it is...but look into that as well.
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
Steezy96yota
07-06-2015 10:00 AM
