98 3.4 won't start, has codes for maf and igniter
Old 03-31-2014, 06:48 PM
DMG
DMG's Avatar
98 3.4 truck had a fire, I replaced the entire dash and body harness. Everything works, fuse and relay centers were replaced too but the truck will crank and barely run for a few seconds before puttering out.
There are codes for maf and igniter. Both are getting power. I swapped them with known good units from another truck. I ohmed out the wires back to the PCM and they were good.
I know I am missing something. Not sure what.
Also, the truck did not have cruise control. The new harness is from a truck with cruise. Could that be an issue?
Could the harness have a different pin out?
Old 04-01-2014, 12:10 AM
wyoming9's Avatar
Red face
Did you also replace the engine harness??
Did you use the ECM with the harness??
Or use yours if so was the harness out of the same year and trans??
The cruise control on both mine are removed and it makes no difference.
Old 04-01-2014, 12:36 AM
totally a bro
Staff
vital22re's Avatar
Cruise has no bearing on it running. Will it stay running on starting fluid? If so then you have a problem with wiring to the circuit opening relay. What year harness did you use? And from what?
Old 04-01-2014, 04:00 AM
DMG
DMG's Avatar
I used a harness from the same year. I replaced body and engine harness. I bought another PCM and it didn't change anything.
I seem to be getting power to the maf and igniter which indicates the circuit opening relay is working, correct?
Old 04-01-2014, 01:00 PM
totally a bro
Staff
vital22re's Avatar
Nope. Maf sends a signal to the Cor to kick on the fuel pump when it senses engine is pulling vacuum *starting*
Old 04-01-2014, 01:01 PM
totally a bro
Staff
vital22re's Avatar
Is it the old style maf? giant inline tube? or the drop in style?
Old 04-02-2014, 12:33 PM
DMG
DMG's Avatar
Big inline tube type.
Old 04-02-2014, 12:34 PM
DMG
DMG's Avatar
Ok. I had that backwards.
Old 04-03-2014, 12:00 AM
wyoming9's Avatar
Red face
The second ECM was it known to be good??
Do you have the diagnostics for your 98 engine?? So you can check the ECM and the igniter and the MAF
Old 04-03-2014, 02:24 AM
totally a bro
Staff
vital22re's Avatar
The wiring for that comes directly through the engine harness that you replaced. Its possible that your new harness may have been early 99 in which case the pin out at the maf plug would be slightly different. However the Igniter pin out at the plug I believe is the same. Are you sure you have all your grounds hooked up on the harness? Maybe both maf and Igniter are missing the grounds it needs from the ecu which it gets from the engine harness.
Try starting and running the rig on starting fluid. If it will cough sputter run then we can at least know its not getting fuel.
Old 04-25-2014, 10:27 AM
DMG
DMG's Avatar
It runs on ether. What wire should feed the fuel pump?
Old 04-25-2014, 10:59 AM
totally a bro
Staff
vital22re's Avatar
Find the location of the COR *circuit opening relay* It powers the fuel pump. But it needs a signal from the MAF.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 98 3.4 won't start, has codes for maf and igniter
