97 toyota tacoma 2.7 noisy valves
Old 04-15-2009, 10:07 AM
larry bliss's Avatar
Have a 97 tacoma (2.7) less then 100k, It has just stared getting noisy on top, Does not do it when cold, Do you think I need a Valve adjustment? One more thing, I have been losing water, Can`t see where it`s going, Does not get hot, No water in oil, Thanks in advance for any help,
Old 04-16-2009, 05:39 AM
Help
Can any one help me with this problem? Thanks in advance..
Old 04-16-2009, 05:59 AM
HazMat's Avatar
Time for a new Water Pump???? when the seal starts to go it can loose water verrrrry slowly so that you would not see a puddle or anything. Can you smell anything...?
Old 04-16-2009, 07:28 AM
No smell, I looked around the water pump and did not see any thing..
Old 04-16-2009, 07:50 AM
hross14's Avatar
Check your valve lash--that will tell you whether you need an adjustment or not
Old 04-16-2009, 07:49 PM
Skrillah's Avatar
How would you check that....
Old 04-17-2009, 06:32 AM
hross14's Avatar
This really should be in the newbie section--this is pretty basic.
but the short answer--put feeler gauge under the lobe and see which one slides in between the bucket (on shim and bucket) and the cam. Check number and compare to specs--adjust as needed
Old 04-17-2009, 07:06 AM
Just found out it is a head gasket, Got water in the oil, Looking for some one to fix it now, Hope it did not hurt the engine, I stoped driving it, Thanks for the help guys, I`ll let you know how it goes....
taraf
09-24-2015 08:33 PM
PureTacoma_Tundra
PureTacoma_Tundra
06-29-2015 09:45 AM
renorunnerguy
3.4 Swaps
06-28-2015 09:18 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
kctopher
06-16-2002 04:07 PM
Quick Reply: 97 toyota tacoma 2.7 noisy valves
