| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
97 SR5 Tranny Acting Up
__________________
Project OSIRIS |
#2 (permalink) |
What I'd do:
-Check the fluid level, replenish or drain as necessary to achieve the correct level. -Next, have the tranny flushed and the ATF replaced with a quality product, like Mobil 1 synthetic ATF. I'd not bother to do only the "drain and refill" service, as this only replaces c. 20% of the ATF in the system. BTW, I changed to Mobil 1 ATF at ~30K miles in my '98 'Runner and had excellent performance (including towing 4,000 # for thousands of miles in hot weather) until I sold the truck at 75K miles. In my experience, shocking things happen to cars that sit undriven for long periods! Best regards and good luck!
__________________
-Karl '03 Titanium Limited, 4WD, V-8 Ex '98 4Runner Limited 4WD auto '07 Porsche GT3 '88 Porsche 911 (For Sale!) |
#3 (permalink) |
tranny
Its usually not the tranny. Have you greased the drive lines latley? Especially the double cardan joint on the main drive line sounds like its sticking.
#4 (permalink) |
I've seen similar transmission behavior when the fluid level is too low. But after being parked so long, a flush probably isn't a bad idea.
__________________
Jon 97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets |
#5 (permalink) | |
Quote:
is greasing the drive lines something i can easily do myself? any write ups on it in the tech section?
__________________
Project OSIRIS |
#6 (permalink) |
greasing driveline
Yes its very simple get a grease gun and grease all the zerk fittings on the drive lines. You will find a diagram of all the zerks in your owners manuel or my 91 also has it on the sunvisor as well. You are suppossed to grease the driveline at specific intervals check your owners manuel. My brother has a 97 as well had same problem greased drive lines and its fine. your tranny is actaully shifting fine its the double cardan joint in the middle of your main drive line popping beacause it has no grease its has several joints in one assembley it has 2-4 zerks so make sure you get them all just a slight pump in each one you will hear air escapping from joint as you grease then you stop piece of cake. make sure you wipe away dirt from zerk fisrt then grease.
#7 (permalink) | |
Quote:
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Roor Runner's 97 SR5 | MillerPKA | 4Runners-3rd gen | 7 | 03-10-2009 06:01 PM |
| '97 Limited vs. SR5 | Portdogmc | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 12-02-2006 03:12 PM |
| 97 2WD SR5 Needs Tips | bottle286 | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 04-18-2005 10:43 PM |
