97 Runner 3.4 Runs rough
Old 06-23-2011, 01:33 PM
toytim's Avatar
I have a 97 runner 3.4 auto 4x4.
I have cleaned the IACV,MAFS, and dropped new plugs in it not too long ago along with a new O2 sensor.
Runs rough in the morning and smooths out after a bit. Just recently it started cutting out real bad under a load. up hills or under hard accleration it felt like it was starving for fuel. it did slightly overheat a couple times last week but nothing that caused too much headache. has not overheated since.
OK After searching and searching i am gonna start tackiling this pita.. I'm gonna start easy and cheap before i start dumping bucks!
If anyone has any words of wisdom im open for anything..
AND..... To top it off took it to a friend for his opinion today and it ran like a champ the whole time! NO ISSUE!! WTF???
Old 06-23-2011, 01:40 PM
Staff
DeathCougar's Avatar
Start checking obvious things;
TPS, AFM, Injector pulse, wires, and coils. Make sure all these parts are operating correctly. They can all be checked with an FSM and a Voltmeter (Ohms tester)
Old 06-23-2011, 02:07 PM
toytim's Avatar
Thanks! gottta keep chopping at it to narrow it down.. it has no codes at all and my cel has never came on which is pretty annoying but i guess its better then seeing a last chance light..
Old 06-23-2011, 08:19 PM
tbennett13's Avatar
Give this a try, when the vehicle is on a col start take a bottle of carb cleaner and spray it around the intake manifold. A leaking intake gasket can cause this problem by starting out rough then expanding when hot properly sealing agian then making the vehicle run fine agian.
Old 06-24-2011, 07:35 AM
tunnelmotor99's Avatar
Bad or grounding out plug wires will cause the conditions you reported. Get yourself a new set and replace them one at a time so they don't get mixed up. Make sure the wires are secured in their clips and not touching any metal.
Old 06-26-2011, 10:02 PM
Ron Helmuth's Avatar
I presume it is not throwing any check engine codes.
If not I always recommend folks consider a new fuel filter. There is some debate that the filter is a 'lifetime' part but having seen the black gunk that comes out of old ones I scoff at that notion.
Also I would not ignore the overheating issue.
Good luck-you have several of us interested. Please let us know what develops.
Old 06-27-2011, 04:47 AM
waskillywabbit's Avatar
Did it act like this before you did all the things in your first post?
:wabbit2:
Old 06-28-2011, 06:24 AM
toytim's Avatar
Why Yes Mr. Wabbit it did.. Each time i tried something new it seemed like it was just a bandaid for a bit.. It has not even really gotten too hot.. Just hotter then normal.. a couple times i heard heat gurgles.. has thrown no codes at all. I'm thinkin my HG is going south. I have had to top off the radiator now 2 times in the last week. with nothing more then a couple quarts. That is too much coolant to lose with NO indication of leaking. I think im just gonna "keep on keepin on" until I know for sure WTH?
It does have about 240,000 miles on it so maybe its time to start lookning into a motor if i have a blown HG...
Yont283
09-23-2022 08:06 PM
puffin04
07-10-2015 09:17 PM
Alex Bessinger
06-28-2015 10:05 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Quick Reply: 97 Runner 3.4 Runs rough
