97 limited 4runner No crank no start
Just bought a 97 limited toyota 4runner with 3.4 v6 and auto transmission.
Wont crank over. No clicks. all lights and everything works
good battery
new starter
maybe neutral safety switch?
i can jump the starter and starts up and runs.
i ran new battery cable and no luck as well.
anyone have wiring diagram for Neutral safety switch so i can bypass it to see if the switch is bad because those are expensive!
thanks
good battery
new starter
thanks
i have check all fuses and they are good. i replaced the starter relay as well.
i have hooked to a big battery charger as well. hmm maybe the battery is junk! when i turn the key to crank the engine over the clock and radio lights go dead as if it cuts the power. battery holds 12volts but like ya say not always good. i was thinking it was a ground issue.
thanks
thanks
figured it out! the aftermarket alarm previous owner had was tapped in to the signal wire for the starter solenoid. well cut that crap out and it starts. not bad i guess for $1200 bucls.
jmc88runner
06-18-2015 03:39 PM
