97 4rnr rear window problem
The rear window on my 97 4rnr will not go down, and the rear wiper will not work. I thought I might have to reset something and tried to lower the rear winder with the key switch on the gate, but that doen't work either. The problem started after I replaced the battery. Any Ideas?
Thanks
Keith
Thanks
Keith
Just a shot have you checked for 12V and a good ground back there? check the fuse...
this has some info
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
this has some info
have you tryed using the key in the back to open the window? make sure the wiper is properly seated on the holder. it is pretty common for the tailgate ecu to go bad. i had replaced mine once. and shortly after it failed yet again. i now just ran new wires to the motor and use a drill battery to operate it.
Yes, I did try to move the rear window with the key. No go. I have to find time to try jumping it. The bigger problem is not having a rear wiper in the winter weather.
As it turns out, the problem was with the rear window switch in the liftgate. I was having problems with the battery draining over night, and the rear window and wiper not working. I used a test lead on the wires to the rear window motor, and found that the motor had a constant hot wire going to it. That was my battery drain. I found that the switch had gone bad and the motor was always trying to raise the rear window. I unplugged the switch, and now everything works fine. I just cant raise the rear window with the key switch in the liftgate. Simple fix, just had to get the time to look into it.
06-01-2021 01:51 PM
icentropy
07-11-2015 07:21 AM
Jnkml
07-06-2015 01:20 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
