YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-07-2008, 07:43 PM   #1 (permalink)
Nehalem i7's Avatar
96 Tacoma Oil shooting out of tailpipe
Hey guys I just had a quick question, I have a 96 Tacoma Reg Cab 2wd with the 2rz that I bought in June and I've had this problem for a while now.
http://www.new.facebook.com/photo.ph...5&id=672760631
As you can see there is oil literally coming out of the tailpipe. I use about 2 quarts a week. The engine gets good mileage and other than this runs perfectly. The thing that worries me about this is that the previous owner told us that he had the engine rebuilt 10,000 miles ago. (150K)
Any thoughts on what the problem is would be appreciated.
Thanks!
Nehalem i7 is offline
Sponsored Links
To remove this ad, register today!
Old 09-07-2008, 08:35 PM   #2 (permalink)
111db's Avatar
Send a message via MSN to 111db
Haven't run across that before. I believe if the rings were allowing blow-by, then you'd have oil combustion and blue-ish white smoke. Not being familiar with that particular engine I would guess that you have oil leaking around the valve guides into the exhaust side. At a minimum you should check the compression and probably then have the head looked at for seals and/or cracks. I'm surprised you don't have a CEL for a damaged catalyctic converter or 02 sensor.
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 09-07-2008, 08:43 PM   #3 (permalink)
Are you sure you even have a catalytic converter thats not hollow? It should be burned up and come out as smoke! You might want to pull the plugs and see which cylinder has oil in it. But either way, the rebuild didn't go as planned, that's for sure.
__________________
'99 4WD 3.4L SR5 AT
DailyDrive is offline
Old 09-08-2008, 08:10 PM   #4 (permalink)
Nehalem i7's Avatar
@111DB: Yeah thats what my Dad thought it was. Glad its likely not the rings as that would be a ton of $$$ to fix. I'll tell him what you recommended. If his STi was doing this it would've been fixed a long time ago...
@DailyDrive: I took a pic of it IDK if you can tell what it is by looking at it. It doesn't smell like my dad's STi (no cats) and it passed emissions in June so I assume it works (we'll see how long that lasts...)
http://www.new.facebook.com/photo.ph...a&id=672760631
Thanks!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Water coming out of tailpipe? my4runner Newbie Tech Section 12 07-29-2008 01:22 PM
Squeelin sound from tailpipe stylistic_99 95.5-2004 Tacomas & 96-2002 4Runners 8 06-06-2008 07:58 PM
Stock tailpipe size for V6 the_supernerd 95.5-2004 Tacomas & 96-2002 4Runners 1 01-17-2005 07:36 PM
sut coming out of tailpipe PAULV3 Maintenance & Repair Archives 2 03-25-2004 11:21 AM
Smashed tailpipe. Possible solutions? Nitro Hotpants 95.5-2004 Tacomas & 96-2002 4Runners 10 01-20-2004 02:27 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
