Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
96 Tacoma Oil shooting out of tailpipe
Hey guys I just had a quick question, I have a 96 Tacoma Reg Cab 2wd with the 2rz that I bought in June and I've had this problem for a while now.
http://www.new.facebook.com/photo.ph...5&id=672760631 As you can see there is oil literally coming out of the tailpipe. I use about 2 quarts a week. The engine gets good mileage and other than this runs perfectly. The thing that worries me about this is that the previous owner told us that he had the engine rebuilt 10,000 miles ago. (150K) Any thoughts on what the problem is would be appreciated. Thanks! |
| Sponsored Links |
#2 (permalink) |
Haven't run across that before. I believe if the rings were allowing blow-by, then you'd have oil combustion and blue-ish white smoke. Not being familiar with that particular engine I would guess that you have oil leaking around the valve guides into the exhaust side. At a minimum you should check the compression and probably then have the head looked at for seals and/or cracks. I'm surprised you don't have a CEL for a damaged catalyctic converter or 02 sensor.
__________________
Jon 97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets |
#3 (permalink) |
Are you sure you even have a catalytic converter thats not hollow? It should be burned up and come out as smoke! You might want to pull the plugs and see which cylinder has oil in it. But either way, the rebuild didn't go as planned, that's for sure.
__________________
'99 4WD 3.4L SR5 AT |
#4 (permalink) |
@111DB: Yeah thats what my Dad thought it was. Glad its likely not the rings as that would be a ton of $$$ to fix. I'll tell him what you recommended. If his STi was doing this it would've been fixed a long time ago...
![]() @DailyDrive: I took a pic of it IDK if you can tell what it is by looking at it. It doesn't smell like my dad's STi (no cats) and it passed emissions in June so I assume it works (we'll see how long that lasts...) http://www.new.facebook.com/photo.ph...a&id=672760631 Thanks! |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Water coming out of tailpipe? | my4runner | Newbie Tech Section | 12 | 07-29-2008 01:22 PM |
| Squeelin sound from tailpipe | stylistic_99 | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 06-06-2008 07:58 PM |
| Stock tailpipe size for V6 | the_supernerd | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 01-17-2005 07:36 PM |
| sut coming out of tailpipe | PAULV3 | Maintenance & Repair Archives | 2 | 03-25-2004 11:21 AM |
| Smashed tailpipe. Possible solutions? | Nitro Hotpants | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 01-20-2004 02:27 AM |
