96 Tacoma Locking Hubs Problem
Old 04-10-2014, 11:29 AM
FlushT's Avatar
I have a 96 Tacoma Standard cab manual trans with the 2.7 in it. When I first go the truck the Front Diff was shot in it so I bought a used one for it swapped it out the 4wd still wouldn't work. So I decided to buy new locking hubs for it. It had warn hubs on it but they were completely shot when I took them off. I bought the Mile Marker hubs for it however when I went to install them the gears on the inside of the locking hubs will not go down to the end of the CV axle. Can anyone give me a reason why they wont?
Old 04-10-2014, 11:36 AM
wyoming9's Avatar
Red face
Wrong hubs packed in the correct box.
wrong hubs for your truck??
Old 04-10-2014, 11:40 AM
FlushT's Avatar
It's possible... Just wondering if maybe I need the nut conversion kit they offer or what... I know nothing about manual hubs
Old 04-10-2014, 11:48 AM
wyoming9's Avatar
Red face
If you took the Warn Hubs off if these are the correct ones they should go right on.
Old 04-10-2014, 11:51 AM
FlushT's Avatar
Yea but what bothers me is that the warn ones basically fell apart when I took them off so it's possible that they never even worked in the first place. The guy I got the truck from said he never had the 4wd working in it
Old 04-10-2014, 02:26 PM
wyoming9's Avatar
Red face
It does have the correct hub and CV axles for Manual hubs
The PO did not try and do a Hack job converting to manual Hubs and just gave up or did they??
Does you truck Have the ADD that has been screwed up in a attempt to install manual hubs??
smthwsn357
12-04-2023 02:08 AM
Poncho0206
07-10-2015 06:21 PM
akaphilly
07-09-2015 02:18 PM
AaronM
07-08-2015 07:15 PM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: 96 Tacoma Locking Hubs Problem
