YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 11-01-2002, 03:23 PM   #1 (permalink)
'96 Starting problem?
Hi, I have a '96 Tacoma V6 4WD that has a weird starting problem. It has been going on for about a year now, but seems to be getting worse latetly. Even with the clutch pushed all the way in it will crank real slowly or not at all. We replaced the starter this week with a new Bosch unit and it was fine for a few days, but now it does it again. The battery was tested OK, could this be the ignition switch or clutch switch? Is this a common problem? Anything else we are missing? Thanks in advance.
__________________
www.jadewombat.com
Jadewombat is offline
Sponsored Links
To remove this ad, register today!
Old 11-02-2002, 01:59 AM   #2 (permalink)
jx94148's Avatar
Send a message via Yahoo to jx94148
I don't think its common. Check the cables for corossion on both ends. Sorry I can't be more helpful.
jx94148 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Starting problem Lrowell 86-95 Trucks & 4Runners 5 01-21-2007 09:34 AM
starting problem not your usuall contacts problem instigator 95.5-2004 Tacomas & 96-2002 4Runners 6 12-08-2006 02:59 PM
96 4runner not starting gonzopb 95.5-2004 Tacomas & 96-2002 4Runners 6 09-01-2006 09:04 AM
Couple of questions.. Having trouble starting my 96 4runner Moises357533 95.5-2004 Tacomas & 96-2002 4Runners 0 05-20-2006 09:14 PM
Another STARTING problem!!!!!!!!!!!!!!! 2wheelBLACKOUT Maintenance & Repair Archives 7 05-08-2005 08:47 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
