96 EFI 3.4 temp sensor locations?
Old 06-07-2011, 06:10 AM
roundhouse's Avatar
Got a 96 4.4 runner.
getting the po125 low coolant temp code.
changed the t-stat and the temp sensor in the front of the intake,
Is this the correct sensor?
How do I test the sensor, and lastly, how can i fool the computer into thinking its at the right temp, long enough to pass the emission check?
The smog check is just a plug in deal where it looks for codes in the computer.
I can clear the code but it comes right back in few miles.
Old 06-07-2011, 04:41 PM
dntsdad's Avatar
http://home.comcast.net/~dntsdad//In...sed%20Loop.pdf
http://home.comcast.net/~dntsdad//di...de%20chart.pdf
Old 06-07-2011, 06:02 PM
roundhouse's Avatar
So my code scanner saying insufficient coolant temp has nothing to do with the coolant temp?
Its an o2 sensor?
Im barking up the wrong tree for sure.
Old 06-07-2011, 09:02 PM
dntsdad's Avatar
Its an o2 sensor?
It would appear so. At least you know.
Old 06-07-2011, 11:00 PM
hotlavaaaa's Avatar
Its an o2 sensor?
I got p0125 along with P1135 last summer. Replaced the sensor and no cel since. Make sure to use a Denso sensor. Find the right sensor on this list. I ordered mine from Amazon because they had the cheapest price.
http://www.urdusa.com/index.php?cPat...1um342emcob0a5
Old 06-08-2011, 07:03 AM
roundhouse's Avatar
Thanks for the info !
Ive got to get one local, got to pass the smog check by friday.
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
94whiterunner
07-12-2015 07:15 PM
Poncho0206
07-10-2015 06:21 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 96 EFI 3.4 temp sensor locations?
