Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
96 Dune Runner
#2 (permalink) |
Personal
Sales Rating: (0)
[OP]
Ok got a lil carried away with taking things off but this way there is accessibility to almost everything. Once motor and trans we will post another chapter. As of now prolly have three hours of goofing around to get to this point.
tlivi |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
#5 (permalink) |
Personal
Sales Rating: (0)
Can't wait to see more. How about more info on your plans?
#6 (permalink) |
Personal
Sales Rating: (0)
What are your plans for suspension?
__________________
1996 Runner limited, V6 4wd, 5sp 5.29 gears Supercharger/under pulley/ URD's fuel/timing kit Suspension-Sway-a-way 2.5 coilovers and camburg uniball uppers, gusseted spindles, strapped, Cruiser springs and heim'd links in rear.Tires and wows-35x12.50 Goodyear MTR's on 15x8 black steels, cut fenders and cut back firewall. Misc-spool in rear, Cobra Cb, CO2 tank, Bud Bulit Skids, K&N intake, flowmaster exhaust. Power Steering Cooler, 140 amp alt, 8K winch, Superior axles, aluminum fuel cell. |
#7 (permalink) |
Personal
Sales Rating: (0)
I am gonna follow this build. What transmission are you gonna use?
__________________
If you don't break something, your not trying hard enough. If you break a lot.. your probably not driving a Toyota. FUTURE UPGRADES INCLUDE LEXUS 4.0 SUPERCHARGED 1UZ-FE MOTOR ON LIQUID PROPANE DIRECT INJECTION, 4L60E AUTO WITH ATLAS 3 SPEED TRANSFERCASE SUPRALUX FRONT 8INCH DIFF AND AXLE SWAP http://toyotasurf.asn.au/forum/viewt...light=supralux |
#8 (permalink) |
Personal
Sales Rating: (0)
[OP]
We are using the combination out of a 97 aristo so the engine is a 2jz-gte vvti with a A340e trans I really don't feel like doing another clutch conversion plus I would eventually like for my daughter to be able to drive it earlier than normal.... lol. She just turned one lol..... anyway we have ecu, harness, maf, from what i can tell appears everything lol. So working on xhaust not sure with that yet, looking for an extreme sleeper until about 4500 then listen to everything around go ballistic the higher the range. I am looking at a few coil over conversion suspension kits I have found a few good, well from looking at them, kits I just would like to have a little more knowledge on what's out there before we make a purchase. Ultimately I would like to have something close to a pro buggy for the travel but yet still driveable. We live close to silver lake sand dunes so that's our purpose of the build, plus the trails through the surrounding areas, as well as a part time daily driver hahahaha... thank you all for your interest shall keep y'all updated......
tlivi |
#9 (permalink) |
Personal
Sales Rating: (0)
what are you doing transfer case wise? axles? gearing? tires?
motor wise, keeping it twin? or going single, stock power, or upgrading, what about fuel delivery, any thoughts? |
#10 (permalink) |
Personal
Sales Rating: (0)
[OP]
As of now the 2x4 will remain the same once I have the motor/trans in my possession we are going to dig deeper into different axle swaps. We have done a comparison into the differences in the trans ratio's from the supra & aristo to the 96 4runner just for peace of mind and they are fairly similar. Now taken into perspective tire sizes are different obviously I have seen a few different varieties of wheel and tire size, packages, that are of interest. A few sets require fabrication to the fenders. We will be removing the running boards and fender trim to allow a little more clearance, however, I have also found rocker savers to replace the boards. I will get more on to that when it gets a little closer. Now looking into fuel delivery I have a few different areomotive pumps and related pieces that should work again once I have motor & trans I will see what is able to be used for sure. Thank you for keeping the wheels turning sometimes those little things get over looked or forgot about ....
tlivi |
#11 (permalink) |
Personal
Sales Rating: (0)
Sounds like you're fairly on top of things.
I went with the aristo 2jzgte vvti as well, I'm going inchworm lexus adaptor to dual transfer cases. As far as fuel, I'm running a fuel cell I mounted under the floor, fuelab pump, filter, and regulator, upgraded my injectors to be e85 capable, and am running AEM. The standalone isn't cheap, but really helps getting the power and shift points where you want them for a truck/4x4 application. |
#12 (permalink) |
Personal
Sales Rating: (0)
[OP]
Any good suggestions for drive shaft and motor mounts I dont foresee these being a huge issue would like to see what im missing. Is there a way to convert the aristo a340e to a slip yoke or do i purchase the two piece drive shaft from the aristo and convert the pinion joint...... thank you......
tlivi |
#13 (permalink) |
Personal
Sales Rating: (0)
Motor mounts are super easy, you'll understand when you see them, just cut yours out of the way, and make a new frame side mount.
Drkveshaftss were in different boats, i removed the tailhousing off my a340e, and I've got 2 feet of transfer case back there. |
#14 (permalink) |
Personal
Sales Rating: (0)
[OP]
Awesome thank you....... :-) as far as the t-case im keeping mine 2x4 so i will have to figure that out once that time comes. We are about three weeks from getting our engine trans and goodies gettin EXCITED!!!!!!!!!
tlivi |
#15 (permalink) |
Personal
Sales Rating: (0)
ever torn into an auto trans? I'm like 90% certain that if you pull the tailhousing, and input shaft from you're current a340, and throw them into your 2jz a340e, then that is all you're issues settled.
#16 (permalink) |
Personal
Sales Rating: (0)
Nice man, good luck...Im going to follow your progress..
__________________
Fully Locked Supercharged 2003 Tacoma SR5 Extra Cab V6 5speed 4X4, with some mods....My Truck My photography http://www.flickr.com/photos/andrewkumler/ |
#17 (permalink) |
Personal
Sales Rating: (0)
[OP]
Never even thought of that well I dont have it yet so i cant physically see it lol but yeah ive been into an auto trans a few times ive read a few other forums of people doing that with the tail housing im sure a lot of things will make sense once I have everything in front of me... thank you again you have been very informative on my concerns. Much appreciated :-)
tlivi |
| Tags |
| 96, board, engine, powered, runner, running, tundra, vbulletin |
