96-98 4Runner - Do They Come Prewired For The Foglights?
Old 12-26-2003, 07:10 AM
Vato Loco's Avatar
I was wondering do the 96-98 4Runners come prewired for the stock Hella foglights? Because mine didn't come with foglights and might be purchasing the foglights from Perrformance Product. Thanks
Old 12-26-2003, 07:34 AM
4Runnerman's Avatar
The 1996-1998 4Runners do not come prewired for the foglights. However, the kit includes the wiring harness, connectors, and instructions, so installation is pretty staightforward.
If you do order the foglights, I would recommend getting some H3 bulbs that have a gold or yellow tinge. I've found they work much better at cutting through fog and illuminating wet or icy roads.
Good luck.
Old 12-26-2003, 07:36 AM
SLC Punk's Avatar
Yep what 4Runnerman said.
I think i am going to try some fog (yellow) bulbs.
Old 12-26-2003, 08:09 AM
lee
lee's Avatar
oh, you mean people use fog lights for fog?
i installed some Hella Optilux 1000's right on my grille guard, but will probably spring for the factory-style or actual oem ones later on.
Old 12-26-2003, 08:18 AM
phosho's Avatar
Mount ?
Vato, have you decided where to mount your fogs? I've been floundering wether to get the PP valence and fogs or attempt to cut and mount through the existing valence. In the mean time I've put some Hella free form fogs and mounted them on the bottom of the bump stops just behind the valance. They sit pretty flush under the valence without having made any permanent changes but it sure dont look very clean or "ome".
http://www.performanceproducts.com/P...producttype=20
Old 12-26-2003, 08:25 AM
Vato Loco's Avatar
I plan on putting them in the stock location like in the picture below thats if I do purchase it.
Old 12-26-2003, 08:47 AM
phosho's Avatar
96-98
What year is your rig? It is the one in the avatar right?
Old 12-26-2003, 08:51 AM
Vato Loco's Avatar
Re: 96-98
Yep!
Old 12-26-2003, 09:01 AM
phosho's Avatar
The fogs In the pic look like the Toyota aftermarket factory fogs. My dealer and a couple others have told me that they have been discontinued and are no longer availible. I'm sure you can jimmy rig somthing to mount lights there or find those OME lights on Ebay or in a yard. If you finalize somthing please post some pics Im in a similar dilema. Thanks
Old 12-26-2003, 09:19 AM
lee
lee's Avatar
when i went to ask my trusted car guy's advice on rigging up my fogs (after noticing the lack of prewiring!), he'd told me many people would cut through some of the plastic in the front to install foglights. i didnt like the sound of that, but its an idea.
Old 12-26-2003, 10:28 AM
Runner4's Avatar
I can't see the picture posted but if they are in the same position as the stock fog lights are then there is an alternative - and a fairly cheap one. I bought a pair of Pilot fogs from Autozone for $19.99, a $3.00 relay, and an OEM Toyota switch to fit the cutouts. I have the PL-1062 shown here:
Pilot Automotive
I mounted them to the plastice valence by drilling a hole and bolting them on. You can actually reach the underside of the valence to secure a nut and bolt. Before mounting a had to Dremel out about 1/4" of plastic from the valence louver to fit them flush. I have had them on for over a year now with no problems at all. Sorry, but I don't have a picture to post. For a total of about $40.00, they work just as good as the expensive, high end lights.
Old 12-26-2003, 10:30 AM
phosho's Avatar
The wiring is pretty straight forward its the mounting location thats very limiting on the 96-98. Gadget and Jason Burtman found thier solutions in the PP spoiler. Its pricey but is looks factory.
http://www.gadgetonline.com/light.ht...ucts%20Spoiler
http://www.burtmanindustries.com/lenses.html
Old 12-26-2003, 10:37 AM
Beachrunner's Avatar
VL...
I'm sure you already know, but installing those OEM fogs is a breeze. I swapped a valance with a guy who had the OEM fogs (my valance didn't have fog locations). Using a sharp box cutter, we went through that plastic like butter.
I suggest looking at one with fogs up close and measure twice, because if you cut too much off of the horizontal slat that the bracket attaches to you're screwed.
Good luck!
Vato Loco's Avatar
First link's not working.
Old 12-26-2003, 11:27 AM
blootie's Avatar
stock fogs
Does anyone know what the dimensions of the stock fogs are so that I can match the autozone off-the-shelf fogs as close to oem ('97) as possible. Thanks. -Bruce
Old 12-26-2003, 01:45 PM
Gadget's Avatar
Performance Products sells the same Hella Fog light kit complete with brackets that was used by Toyota as a port installed option.
Gadget
www.GadgetOnline.com
Old 01-27-2004, 04:17 PM
phosho's Avatar
Here is what I ended up doing to mount some hella ff driving and fogs. Cutting the valence was only necessary for the driving lights (upper). I want to upgrade to the 99'+ bumper & valance but its too rich for my mod account now.
Old 01-27-2004, 04:44 PM
lee
lee's Avatar
this is a new pic i took this weekend of mine.
Old 02-02-2004, 01:25 PM
Bennito's Avatar
Gadget
Indeed. If the kit runs 150$ for the DIO or 75$ for a 500 setup, which would you (everyone and/or anyone) go with?
Old 02-02-2004, 02:02 PM
don_davi's Avatar
I just bought 2 pairs of rectangular driving lights. Thinking about using one pair to assist my regular headlights and one pair to assist high beams. What did you use to cut the valence? Is the mounting pretty secure in the sense that, does it shake/vibrate when driving?
Thanks
Davi
ps There's no fog in Texas, just a buncha deer.
Quick Reply: 96-98 4Runner - Do They Come Prewired For The Foglights?
